Salta al contenuto principale
How to Sew Torn Lace
Cosa ti serve
  1. How to Sew Torn Lace, How to Sew Torn Lace: passo 1, immagine 1 di 3 How to Sew Torn Lace, How to Sew Torn Lace: passo 1, immagine 2 di 3 How to Sew Torn Lace, How to Sew Torn Lace: passo 1, immagine 3 di 3
    • Cut a piece of thread around two feet in length.
    • Push the thread through the hole of the sewing needle.
    • Use a thread of matching color to the lace. This guide shows a thread that contrasts with the color of the lace for easier visibility.
    • Pull the thread until the ends meet.
  2. How to Sew Torn Lace: passo 2, immagine 1 di 3 How to Sew Torn Lace: passo 2, immagine 2 di 3 How to Sew Torn Lace: passo 2, immagine 3 di 3
    • Tie two overlapping knots at the end of the thread.
  3. How to Sew Torn Lace: passo 3, immagine 1 di 1
    • Place your lace on a flat and smooth surface.
  4. How to Sew Torn Lace: passo 4, immagine 1 di 1
    • Stick a pin near the hole, holding the lace in place.
    • Be careful with your fingers when inserting the pin.
  5. How to Sew Torn Lace: passo 5, immagine 1 di 3 How to Sew Torn Lace: passo 5, immagine 2 di 3 How to Sew Torn Lace: passo 5, immagine 3 di 3
    • Stitch the two sides of the hole together until you reach the end.
    • Keep stitches close together to avoid gaps in your stitch.
    • Be careful of the needle tip when sewing.
  6. How to Sew Torn Lace: passo 6, immagine 1 di 1
    • Stick the needle through to the back, or inside, of the lace.
    • Be careful of where you hands are placed when sticking the needle through.
  7. How to Sew Torn Lace: passo 7, immagine 1 di 3 How to Sew Torn Lace: passo 7, immagine 2 di 3 How to Sew Torn Lace: passo 7, immagine 3 di 3
    • Tie two overlapping knots to finish the stitch.
    • Keep the knot as close to the lace as possible.
  8. How to Sew Torn Lace: passo 8, immagine 1 di 3 How to Sew Torn Lace: passo 8, immagine 2 di 3 How to Sew Torn Lace: passo 8, immagine 3 di 3
    • Cut off any excess thread at the end of your stitch.
Linea Traguardo
Joanne Lai
Membro da: 11/05/24
157 Reputazione
1 Guida realizzata
UC Davis, Team 3-2, Vidal-Chiesa Fall 2024 Membro di UC Davis, Team 3-2, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S3G2
3 Membri
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 56
Tutti i Tempi: 376
