Salta al contenuto principale
How to Sew On A Press Stud
Cosa ti serve
  1. How to Sew On A Press Stud, How to Sew On A Press Stud: passo 1, immagine 1 di 1
    • Separate the press studs into two halves.
    • The ball
    • The socket
  2. How to Sew On A Press Stud: passo 2, immagine 1 di 1
    • Gather two and a half feet of thread. Thread the needle.
  3. How to Sew On A Press Stud: passo 3, immagine 1 di 3 How to Sew On A Press Stud: passo 3, immagine 2 di 3 How to Sew On A Press Stud: passo 3, immagine 3 di 3
    • Move the needle to the middle so both sides of the thread are equal lengths.
    • Tie a knot at the end of the thread.
  4. How to Sew On A Press Stud: passo 4, immagine 1 di 2 How to Sew On A Press Stud: passo 4, immagine 2 di 2
    • Tie a second knot over the first one.
    • This will make the knot bigger.
  5. How to Sew On A Press Stud: passo 5, immagine 1 di 1
    • Mark the areas you want to sew the press studs into using a fabric pencil. Make sure the markings are aligned.
    • The ball should be sewn on the inner flap of the top piece.
    • The socket should be sewn on top of the bottom piece
  6. How to Sew On A Press Stud: passo 6, immagine 1 di 3 How to Sew On A Press Stud: passo 6, immagine 2 di 3 How to Sew On A Press Stud: passo 6, immagine 3 di 3
    • Hold down the press stud with your thumb.
    • Poke the needle through only the first layer of the fabric, grabbing only a small bite of the fabric.
    • Push the needle through the hole of the press stud and pull the thread all the way through.
    • If your garment is not double-layered like the one in the guide, the thread will show on the other side.
  7. How to Sew On A Press Stud: passo 7, immagine 1 di 3 How to Sew On A Press Stud: passo 7, immagine 2 di 3 How to Sew On A Press Stud: passo 7, immagine 3 di 3
    • Thread the needle through the fabric next to the first hole you made.
    • Stop before pulling the needle all the way through. There will be a small loop. Thread the needle through the loop and pull.
    • This will create a sturdy knot along the outer rim of the press stud.
  8. How to Sew On A Press Stud: passo 8, immagine 1 di 2 How to Sew On A Press Stud: passo 8, immagine 2 di 2
    • Repeat the previous step and continue to sew along the first press stud hole (at least four times total).
    • Make sure the knots made by the loops fall next to each other, not on top.
  9. How to Sew On A Press Stud: passo 9, immagine 1 di 2 How to Sew On A Press Stud: passo 9, immagine 2 di 2
    • Once you have completed sewing along the first hole, insert your needle through the fabric of the next hole. Pull the thread all the way through.
    • Repeat Steps 7-9 until you finish sewing through all four holes of the press stud.
  10. How to Sew On A Press Stud: passo 10, immagine 1 di 3 How to Sew On A Press Stud: passo 10, immagine 2 di 3 How to Sew On A Press Stud: passo 10, immagine 3 di 3
    • Once all the holes are sewn through, insert the needle through the thread of the hole you ended on.
    • Pull the thread until you make a small loop. Insert the needle through the loop and pull all the way.
  11. How to Sew On A Press Stud: passo 11, immagine 1 di 1
    • Cut the excess thread. Your press stud is now completely sewn on!
    • Follow the exact same steps for the socket.
Linea Traguardo
Emily Pang
Membro da: 04/11/21
193 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 61
Tutti i Tempi: 4,144
