Salta al contenuto principale
How to fix a Samsung Galaxy S5 that is not charging
Cosa ti serve
  1. How to fix a Samsung Galaxy S5 that is not charging, Check Charging Port: passo 1, immagine 1 di 1
    • Note: Images here are from the internet for reference only but not from me
    • Check the charging port at the bottom of the phone. I used a magnifying glass with light to see because these are very small.
  2. How to fix a Samsung Galaxy S5 that is not charging, Check the pins: passo 2, immagine 1 di 1
    • When I checked the pins in my phone, I saw 3. with the one on the rightmost having 2 layers. This was because one of them was bent making it look like there were only 3 instead of 4
    • I used a needle to push the bent pin. After a few pushes, it started charging again!
    • Reminder: be very careful when pushing the pins. I only did this because my phone was not charging at all and I was ready to get a replacement for the charging port if it still didn't work
Conclusione
Altre 10 persone hanno completato questa guida.
SLomat
Membro da: 05/16/18
360 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 56
Tutti i Tempi: 6,121
