Salta al contenuto principale
How to Reuse Dry Nail Polish
Cosa ti serve
  1. How to Reuse Dry Nail Polish, How to Reuse Dry Nail Polish: passo 1, immagine 1 di 1
    • Find a clean workplace where you can easily clean up spills.
    • DO NOT USE ACETONE TO THIN THE NAIL POLISH. Acetone is a solvent for removing nail polish. It can make the nail polish work but, the end result is dull or lumpy nail polish.
    • You can use a few drops of 91% isopropyl alcohol or ethyl acetate as solvents for thinning nail polish.
  2. How to Reuse Dry Nail Polish: passo 2, immagine 1 di 2 How to Reuse Dry Nail Polish: passo 2, immagine 2 di 2
    • Open the bottle of dry nail polish setting the brush to the side.
    • Open the bottle of nail polish thinner.
    • Squirt 2 drops of nail polish thinner into the dry nail polish.
    • Screw the top back onto the dry nail polish and roll the bottle between your hands to mix. Shaking the bottle can put air bubbles in the nail polish and ruin a manicure.
    • Be careful to not not spill any nail polish thinner.
  3. How to Reuse Dry Nail Polish: passo 3, immagine 1 di 2 How to Reuse Dry Nail Polish: passo 3, immagine 2 di 2
    • If the nail polish is still dry or thick repeat steps 2-3 until the nail polish is finally thinned.
    • Do not apply too much nail polish thinner, this will result in watery nail polish.
Conclusione
The nail polish should reach its regular consistency after applying the nail thinner. You may then be able to apply your nail polish onto your nails.
Altre 6 persone hanno completato questa guida.
Iridian Vaca
Membro da: 04/09/15
289 Reputazione
1 Guida realizzata
Cal Poly, Team 28-5, Green Spring 2015 Membro di Cal Poly, Team 28-5, Green Spring 2015
CPSU-GREEN-S15S28G5
3 Membri
10 Guide realizzate
Un commento
If the nail polish is just thick, you can run hot water over the bottle for a few minutes to thin it down some. You don't want to shake a bottle of nail polish to mix it, it can put air bubbles in the mixture, instead roll the bottle between your hands. Nice first guide, GL here.
ABCellars - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 19
Tutti i Tempi: 26,090
