Salta al contenuto principale
How to Reupholster a Bench Cushion
Cosa ti serve
  1. How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: passo 1, immagine 1 di 3 How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: passo 1, immagine 2 di 3 How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: passo 1, immagine 3 di 3
    • Remove the base from the frame of the bench.
    • If the base is screwed on the frame, use a screwdriver or a drill to remove the screws.
  2. How to Reupholster a Bench Cushion: passo 2, immagine 1 di 3 How to Reupholster a Bench Cushion: passo 2, immagine 2 di 3 How to Reupholster a Bench Cushion: passo 2, immagine 3 di 3
    • Lift the staples with the flathead screwdriver before going in with the pliers.
  3. How to Reupholster a Bench Cushion: passo 3, immagine 1 di 3 How to Reupholster a Bench Cushion: passo 3, immagine 2 di 3 How to Reupholster a Bench Cushion: passo 3, immagine 3 di 3
    • Use a pair of pliers to grip the staples.
    • Twist and pull the staples to remove them from the bench.
  4. How to Reupholster a Bench Cushion: passo 4, immagine 1 di 3 How to Reupholster a Bench Cushion: passo 4, immagine 2 di 3 How to Reupholster a Bench Cushion: passo 4, immagine 3 di 3
    • Place clean material down so the new fabric does not get dirty.
    • Place the fabric with the design face down on top of the clean sheet.
    • Then place the cushion, then the base face down.
  5. How to Reupholster a Bench Cushion: passo 5, immagine 1 di 3 How to Reupholster a Bench Cushion: passo 5, immagine 2 di 3 How to Reupholster a Bench Cushion: passo 5, immagine 3 di 3
    • Keep the safety lock closed when not using the staple gun.
    • When ready to use the staple gun, pull the safety lock down.
    • Insert the staples into the stapler.
  6. How to Reupholster a Bench Cushion: passo 6, immagine 1 di 3 How to Reupholster a Bench Cushion: passo 6, immagine 2 di 3 How to Reupholster a Bench Cushion: passo 6, immagine 3 di 3
    • Pull the fabric taut and staple every 4 inches.
  7. How to Reupholster a Bench Cushion: passo 7, immagine 1 di 3 How to Reupholster a Bench Cushion: passo 7, immagine 2 di 3 How to Reupholster a Bench Cushion: passo 7, immagine 3 di 3
    • Fold the corners of the fabric inward then on top.
    • Staple the fabric down twice for each corner.
    • Cut the excess fabric along the shorter sides of the base length.
    • Place the base back onto the frame.
    • If any screws were removed, screw them back on.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Xochitl Vara
Membro da: 01/26/22
169 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 472
