Salta al contenuto principale
How to Rethread Skateboard Axle Trucks
Cosa ti serve
  1. How to Rethread Skateboard Axle Trucks, How to Rethread Skateboard Axle Trucks: passo 1, immagine 1 di 2 How to Rethread Skateboard Axle Trucks, How to Rethread Skateboard Axle Trucks: passo 1, immagine 2 di 2
    • Begin by removing the wheel by removing the old nut with a skate tool.
    • Remember that you have a stripped axle, so you may need extra force to remove the nut.
  2. How to Rethread Skateboard Axle Trucks: passo 2, immagine 1 di 1
    • Clean off any excess dirt or metal particles with a dry towel.
    • Your towel should be dry. Cleaning the axle with a wet towel may cause the axle to rust.
  3. How to Rethread Skateboard Axle Trucks: passo 3, immagine 1 di 3 How to Rethread Skateboard Axle Trucks: passo 3, immagine 2 di 3 How to Rethread Skateboard Axle Trucks: passo 3, immagine 3 di 3
    • Insert the axle thread tool into the 1/2" socket on the skate tool.
    • With the thread tool in the socket, insert the axle into the tool and turn your skate tool clockwise throughout the entire axle. Once you feel you have reached the end of the axle, unscrew the tool.
  4. How to Rethread Skateboard Axle Trucks: passo 4, immagine 1 di 2 How to Rethread Skateboard Axle Trucks: passo 4, immagine 2 di 2
    • Inspect your threads for their quality. You should now have even threads with deep grooves. If they appear uneven, you may need to go back and repeat step 4.
    • Place your wheel back on the axle.
  5. How to Rethread Skateboard Axle Trucks: passo 5, immagine 1 di 3 How to Rethread Skateboard Axle Trucks: passo 5, immagine 2 di 3 How to Rethread Skateboard Axle Trucks: passo 5, immagine 3 di 3
    • Discard the old wheel nut and replace it with a new one. Tighten the new nut onto the wheel.
    • Ensure that your new wheel nut is seated correctly on the threads.
    • Be careful not to overtighten the new nut to prevent stripping the axle again.
Conclusione
Congrats on learning how to repair a stripped axle. Hopefully this guide helped you get back on your wheels!
Angel A Cardenas
Membro da: 03/25/24
121 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 206
