Salta al contenuto principale
How to Restuff a Plushie
Cosa ti serve
  1. How to Restuff a Plushie, Stuffing: passo 1, immagine 1 di 1
    • Choose an area to open the seam of the plushie.
    • Choose an area where the new stitches will not be as noticeable, such as on an underside or another area that will not be seen.
  2. How to Restuff a Plushie: passo 2, immagine 1 di 3 How to Restuff a Plushie: passo 2, immagine 2 di 3 How to Restuff a Plushie: passo 2, immagine 3 di 3
    • Partially unpick the seam using a seam ripper or pair of scissors (about 2 inches).
    • Be sure to place hands carefully and away from the path of the seam ripper to ensure no injures.
  3. How to Restuff a Plushie: passo 3, immagine 1 di 2 How to Restuff a Plushie: passo 3, immagine 2 di 2
    • Remove all of the old stuffing from the plushie.
  4. How to Restuff a Plushie: passo 4, immagine 1 di 3 How to Restuff a Plushie: passo 4, immagine 2 di 3 How to Restuff a Plushie: passo 4, immagine 3 di 3
    • Fill a sink or bowl with warm water and light detergent.
    • Gently hand wash your plushie.
    • Drain and replace the container with clean and warm water.
    • Rinse off the plushie and wring it until it is no longer dripping.
  5. How to Restuff a Plushie: passo 5, immagine 1 di 1
    • Hang dry the plushie using a hanger or clothesline until completely dry.
    • Machine drying can damage or burn the fabric of the plushie
  6. How to Restuff a Plushie: passo 6, immagine 1 di 3 How to Restuff a Plushie: passo 6, immagine 2 di 3 How to Restuff a Plushie: passo 6, immagine 3 di 3
    • Once dry, fill the plushie with new stuffing.
    • Stuffing the plushie little by little ensures the whole plushie gets re-stuffed properly and evenly.
  7. How to Restuff a Plushie: passo 7, immagine 1 di 3 How to Restuff a Plushie: passo 7, immagine 2 di 3 How to Restuff a Plushie: passo 7, immagine 3 di 3
    • Pull the thread through the eye of the needle.
    • Create a knot at the end of the thread.
  8. How to Restuff a Plushie: passo 8, immagine 1 di 1
    • Fold the fabric of the opening (about 1 cm) inward to create two folds.
  9. How to Restuff a Plushie: passo 9, immagine 1 di 3 How to Restuff a Plushie: passo 9, immagine 2 di 3 How to Restuff a Plushie: passo 9, immagine 3 di 3
    • Insert the needle through the inside edge of the folded fabric
    • Make a stitch in the inside fold and pull the thread through.
    • Insert the needle on the other fold and make a stitch
    • Pull the thread through and alternate stitches until you reach the other side of the opening.
    • Take your time and carefully place your hands in a safe position when inserting the needle into the fabric. This can prevent injures.
  10. How to Restuff a Plushie: passo 10, immagine 1 di 3 How to Restuff a Plushie: passo 10, immagine 2 di 3 How to Restuff a Plushie: passo 10, immagine 3 di 3
    • Thread the needle through the inside stitches to loop and knot the end of the thread.
    • Repeat several times to secure the stitch.
  11. How to Restuff a Plushie: passo 11, immagine 1 di 2 How to Restuff a Plushie: passo 11, immagine 2 di 2
    • Cut the excess thread with scissors.
  12. How to Restuff a Plushie: passo 12, immagine 1 di 1
    • Enjoy your renewed plushie!
Conclusione
Your plushie is now looking almost brand new!
Sally Lee
Membro da: 02/01/24
205 Reputazione
1 Guida realizzata
UC Davis, Team 2-4, Andersen Winter 2024 Membro di UC Davis, Team 2-4, Andersen Winter 2024
UCD-ANDERSEN-W24S2G4
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 25
Tutti i Tempi: 131
