Introduzione
If your lacrosse strings are too tight, too loose, or just generally out of repair, your playing will be negatively affected until you can get a restring. Many sporting goods stores offer this service, but any women's lacrosse player can save themselves time and money if they know how to restring their own stick.
While there are many customizable ways to restring a women's lacrosse stick, this tutorial will set you up with the basics for one of the commonly used styles. This guide will walk you through the steps of stringing a pita pocket, which has a channeled center that provides better hold and release than a traditional pocket.
Before starting this guide, get familiar with the types of strings used for a restring, as well as how to tie a poacher's knot.
Cosa ti serve
Prep the nylon strings for the pocket with a poachers knot.
Create this knot at one end of each nylon.
Wrap the cross-string around the leather, front to back.
Thread the cross-string under nylon and through the second twist of the black cross-string.
Repeat this pattern (steps 15-16) until each twist in the pocket has been threaded through.
Pull the end of the cross-string through the hole of the leather at the bottom.
This guide is a complete replacement of all strings. Each step per string can be done solo if only one string-part of the lacrosse head needs repair.
