Salta al contenuto principale
How to Restore a Dried Out Marking Pen
  1. How to Restore a Dried Out Marking Pen, Soak the tip in isopropyl alcohol: passo 1, immagine 1 di 2 How to Restore a Dried Out Marking Pen, Soak the tip in isopropyl alcohol: passo 1, immagine 2 di 2
    • Fill a cup with enough isopropyl alcohol for the marking pen's tip to be fully submerged.
    • Place the pen into the cup with the tip side down.
    • Keep the pen as upright as possible to prevent the alcohol from going around the side of the pen nib.
    • Wait 15 minutes for the alcohol to soak into the pen tip.
  2. How to Restore a Dried Out Marking Pen, Remove the alcohol: passo 2, immagine 1 di 3 How to Restore a Dried Out Marking Pen, Remove the alcohol: passo 2, immagine 2 di 3 How to Restore a Dried Out Marking Pen, Remove the alcohol: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    FixMat
    $36.95
    • Remove the pen from the cup and wipe off any remaining alcohol from the pen tip.
    • On your FixMat, or another dry-erasable surface, draw the pen back and forth until you see alcohol leaving the pen nib.
    • Rotate the pen while drawing to ensure all sides of the pen nib are exercised.
    • If no alcohol is coming out of the pen nib, repeat the previous step.
  3. How to Restore a Dried Out Marking Pen, Soak the tip in water: passo 3, immagine 1 di 2 How to Restore a Dried Out Marking Pen, Soak the tip in water: passo 3, immagine 2 di 2
    • Fill a cup with enough water for the marking pen's tip to be fully submerged.
    • Keep the pen as upright as possible to prevent the water from going around the side of the pen nib.
    • Wait 30 minutes for the water to soak into the pen tip.
  4. How to Restore a Dried Out Marking Pen, Remove the water: passo 4, immagine 1 di 3 How to Restore a Dried Out Marking Pen, Remove the water: passo 4, immagine 2 di 3 How to Restore a Dried Out Marking Pen, Remove the water: passo 4, immagine 3 di 3
    • Remove the pen from the cup and wipe off any remaining water from the pen tip.
    • On your FixMat, or another dry-erasable surface, draw the pen back and forth until you see ink forming in solid lines.
    • Rotate the pen while drawing to ensure all sides of the pen tip are releasing ink.
    • If no ink is coming out of the pen nib, repeat the previous step.
  5. How to Restore a Dried Out Marking Pen: passo 5, immagine 1 di 1
    • Congratulations! Your pen has been revived.
Conclusione
For more electronics skills guides, click here.
Altre 11 persone hanno completato questa guida.
Alex Diaz-Kokaisl
Membro da: 01/16/22
214.267 Reputazione
1.041 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.758 Guide realizzate
11Commenti sulla guida
Unfortunately this did not help for me.
Sven Alleblas - Replica
This is such a great pen I wish I could find replacements.
lupinm - Replica
Apparently this pen that comes with the FixMat cannot be purchased, but is covered by the lifetime warranty. Send an email to support@ifixit.com to get replacement pens.
P.S. It's called the iFixit Marking Pen
Andrew Chen -
Same for me, I repeated the guide 3 times, it didn't helped, I wish I could just open it and use a replacement, it's cheap to buy but I feel bad of throwing everything, and also the pen dries super fast I think I need to buy another one and just glue some metal plate to use with the I fix it magnetic mat
thematho - Replica
See my reply above
Andrew Chen -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 97
Ultimi 30 Giorni: 388
Tutti i Tempi: 9,228
