Salta al contenuto principale
How to Restore a Dining Chair
Cosa ti serve
  1. How to Restore a Dining Chair, How to Restore a Dining Chair: passo 1, immagine 1 di 3 How to Restore a Dining Chair, How to Restore a Dining Chair: passo 1, immagine 2 di 3 How to Restore a Dining Chair, How to Restore a Dining Chair: passo 1, immagine 3 di 3
    • Begin with an old chair frame.
    • For frames in good condition, continue to step 5.
    • Using your sandpaper, rub any marks or scuffs off the wood.
    • Always rub with the grain of the wood.
  2. How to Restore a Dining Chair: passo 2, immagine 1 di 2 How to Restore a Dining Chair: passo 2, immagine 2 di 2
    • Use the cleaning cloth to wipe off any excess dirt and dust.
  3. How to Restore a Dining Chair: passo 3, immagine 1 di 3 How to Restore a Dining Chair: passo 3, immagine 2 di 3 How to Restore a Dining Chair: passo 3, immagine 3 di 3
    • Holding the spray paint 6-12 inches away from the chair, apply a light coat of paint.
    • Allow it to dry for about 5 minutes.
    • Apply a second light coat over the front of the chair and allow it to dry for 10 minutes.
  4. How to Restore a Dining Chair: passo 4, immagine 1 di 2 How to Restore a Dining Chair: passo 4, immagine 2 di 2
    • Flip the chair over.
    • Repeat step 3 for the back side.
  5. How to Restore a Dining Chair: passo 5, immagine 1 di 3 How to Restore a Dining Chair: passo 5, immagine 2 di 3 How to Restore a Dining Chair: passo 5, immagine 3 di 3
    • While the paint dries, work on the seat.
    • Grab the wood board and set it down.
    • Grab the desired cushion and rest it on top of the board.
    • Make sure to align all four corners of the wood to the corners of the cushion.
  6. How to Restore a Dining Chair: passo 6, immagine 1 di 3 How to Restore a Dining Chair: passo 6, immagine 2 di 3 How to Restore a Dining Chair: passo 6, immagine 3 di 3
    • Now grab the cushion cover.
    • You may use fabric (cut to size) instead of a cushion cover.
    • Place your cover on top of the cushion, aligning all four corners.
  7. How to Restore a Dining Chair: passo 7, immagine 1 di 3 How to Restore a Dining Chair: passo 7, immagine 2 di 3 How to Restore a Dining Chair: passo 7, immagine 3 di 3
    • Grab the stack of wood, cushion and cover and flip it over.
    • Align them so they stack up evenly.
    • Fragments of the cushion cover may stick out a little.
  8. How to Restore a Dining Chair: passo 8, immagine 1 di 3 How to Restore a Dining Chair: passo 8, immagine 2 di 3 How to Restore a Dining Chair: passo 8, immagine 3 di 3
    • Fold the sides of the cover over the board and cushion keeping them as close to the center of the board as possible.
    • Select a side to start on.
    • With the staple gun, staple the end of the cushion cover you are holding into the board.
    • Rotate the board and staple down the other side.
    • Continue to staple down the sides, placing staples about 1 inch apart.
    • Fold the corners in and staple them onto the board.
  9. How to Restore a Dining Chair: passo 9, immagine 1 di 3 How to Restore a Dining Chair: passo 9, immagine 2 di 3 How to Restore a Dining Chair: passo 9, immagine 3 di 3
    • Make sure that the paint on the chair frame has completely dried up.
    • Grab your newly covered cushion and place it on the seat of the chair frame.
    • Holding on to both the cushion and the frame, flip the chair over.
  10. How to Restore a Dining Chair: passo 10, immagine 1 di 3 How to Restore a Dining Chair: passo 10, immagine 2 di 3 How to Restore a Dining Chair: passo 10, immagine 3 di 3
    • Place the screws in the screw holes.
    • Tighten the screws with the philips screw driver.
    • To avoid the wood from cracking, do not apply to much force when turning screwdriver.
  11. How to Restore a Dining Chair: passo 11, immagine 1 di 1
    • Make good use of your brand new chair.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Chuy Mercado
Membro da: 09/29/15
228 Reputazione
1 Guida realizzata
Cal Poly, Team 15-6, Green Fall 2015 Membro di Cal Poly, Team 15-6, Green Fall 2015
CPSU-GREEN-F15S15G6
5 Membri
6 Guide realizzate
2Commenti sulla guida
Do you have any Ideas on fixing a wobble chair before replacing the seat ?
Robert - Replica
Hi, I have a aoks chair I want to restore can you please help
Josefina Mejia - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 30
Tutti i Tempi: 6,958
