Salta al contenuto principale
How to Resize a Metal Ring that is Too Large
Cosa ti serve
  1. How to Resize a Metal Ring that is Too Large, How to Resize a Metal Ring that is Too Large: passo 1, immagine 1 di 2 How to Resize a Metal Ring that is Too Large, How to Resize a Metal Ring that is Too Large: passo 1, immagine 2 di 2
    • Find the metal ring that is too large for your finger.
  2. How to Resize a Metal Ring that is Too Large: passo 2, immagine 1 di 2 How to Resize a Metal Ring that is Too Large: passo 2, immagine 2 di 2
    • Tear off a quarter size of soft clay.
    • The soft clay will act as a mold that will enlarge the metal ring.
  3. How to Resize a Metal Ring that is Too Large: passo 3, immagine 1 di 3 How to Resize a Metal Ring that is Too Large: passo 3, immagine 2 di 3 How to Resize a Metal Ring that is Too Large: passo 3, immagine 3 di 3
    • Wear the metal ring.
    • Place the back of your hand flat on a table.
    • Shape the soft clay snugly in the gap between the metal ring and your finger.
  4. How to Resize a Metal Ring that is Too Large: passo 4, immagine 1 di 3 How to Resize a Metal Ring that is Too Large: passo 4, immagine 2 di 3 How to Resize a Metal Ring that is Too Large: passo 4, immagine 3 di 3
    • Remove your finger slowly from the molded soft clay, immediately after shaping the soft clay.
    • If the molded soft clay shifts then repeat Step 3.
    • Wait for the soft clay to dry overnight.
    • To tell if the soft clay is dry, touch the soft clay to see if it has hardened.
  5. How to Resize a Metal Ring that is Too Large: passo 5, immagine 1 di 3 How to Resize a Metal Ring that is Too Large: passo 5, immagine 2 di 3 How to Resize a Metal Ring that is Too Large: passo 5, immagine 3 di 3
    • Remove the soft clay mold from the metal ring.
  6. How to Resize a Metal Ring that is Too Large: passo 6, immagine 1 di 2 How to Resize a Metal Ring that is Too Large: passo 6, immagine 2 di 2
    • Use scissors to trim the mold's extra soft clay sticking out of the metal ring.
  7. How to Resize a Metal Ring that is Too Large: passo 7, immagine 1 di 3 How to Resize a Metal Ring that is Too Large: passo 7, immagine 2 di 3 How to Resize a Metal Ring that is Too Large: passo 7, immagine 3 di 3
    • Limit super glue exposure from skin as it may cause a rash. If super glue comes into contact with skin, soak the skin in warm, soapy water.
    • Adhere super glue on the soft clay mold that will touch the metal ring.
    • Attach the soft clay mold to the metal ring before the super glue dries.
  8. How to Resize a Metal Ring that is Too Large: passo 8, immagine 1 di 3 How to Resize a Metal Ring that is Too Large: passo 8, immagine 2 di 3 How to Resize a Metal Ring that is Too Large: passo 8, immagine 3 di 3
    • Wait 10 minutes for the super glue to dry.
    • Trim the soft clay with scissors again, if needed.
    • The goal of this step is to align the soft clay mold along the metal ring's band.
  9. How to Resize a Metal Ring that is Too Large: passo 9, immagine 1 di 2 How to Resize a Metal Ring that is Too Large: passo 9, immagine 2 di 2
    • If completed, the metal ring should fit!
Linea Traguardo
Helena Sherman
Membro da: 02/18/20
169 Reputazione
1 Guida realizzata
UC Davis, Team S2-G1, Andersen Winter 2020 Membro di UC Davis, Team S2-G1, Andersen Winter 2020
UCD-ANDERSEN-W20S2G1
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 319
