Salta al contenuto principale
How to Repot an Overgrown Monstera
Cosa ti serve
  1. How to Repot an Overgrown Monstera, How to Repot an Overgrown Monstera: passo 1, immagine 1 di 3 How to Repot an Overgrown Monstera, How to Repot an Overgrown Monstera: passo 1, immagine 2 di 3 How to Repot an Overgrown Monstera, How to Repot an Overgrown Monstera: passo 1, immagine 3 di 3
    • Prepare the new pot by filling it around a third full with fresh potting soil.
    • Place the support stake in the desired location so the stake hits the bottom of the pot.
  2. How to Repot an Overgrown Monstera: passo 2, immagine 1 di 1
    • Tip the Monstera slowly onto its side and lift the roots sideways out of the old pot.
    • Support the roots and branches when transferring, and ensure not to break them.
  3. How to Repot an Overgrown Monstera: passo 3, immagine 1 di 1
    • Loosen and remove old soil from the root ball by gently massaging it away from the roots with your fingers.
  4. How to Repot an Overgrown Monstera: passo 4, immagine 1 di 2 How to Repot an Overgrown Monstera: passo 4, immagine 2 di 2
    • Place the root ball in the new pot and place fresh soil around the root ball.
    • Leave an inch or two of space between the soil and the top of the pot.
  5. How to Repot an Overgrown Monstera: passo 5, immagine 1 di 1
    • Adjust the roots and leaves around the stake.
    • Direct any long aerial roots back toward the soil as you adjust the plant in the soil.
  6. How to Repot an Overgrown Monstera: passo 6, immagine 1 di 1
    • Tie the stems of the monstera up and down the stake to obtain even support and keep it upright.
    • Be careful not to break any leaves or stems by tying the plant to the stake too tightly.
  7. How to Repot an Overgrown Monstera: passo 7, immagine 1 di 1
    • Water the monstera well; the plant is properly saturated when water runs out of the holes in the bottom of the pot.
    • Water the plant over a trash bag or something that will catch the excess water.
Conclusione
In all, this is an easy at-home fix to keep a monstera plant healthy. This fix guides the user to remove and re-plant the monstera, and to water it at the end. We advise continued plant care and watering after repotting.
Owen Chen
Membro da: 11/05/24
145 Reputazione
1 Guida realizzata
UC Davis, Team 1-7, Vidal-Chiesa Fall 2024 Membro di UC Davis, Team 1-7, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S1G7
3 Membri
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 142
