Salta al contenuto principale
How to Replace the Wick of a Zippo Lighter
Cosa ti serve
  1. How to Replace the Wick of a Zippo Lighter, Wick: passo 1, immagine 1 di 1
    • Make sure that the Zippo is clear of fuel. If it will light, it is not empty.
    • Leave the Zippo out without its casing in a well ventilated space to speed up fuel evaporation.
    • Remove the lighter from its casing, grabbing by the chimney.
  2. How to Replace the Wick of a Zippo Lighter: passo 2, immagine 1 di 2 How to Replace the Wick of a Zippo Lighter: passo 2, immagine 2 di 2
    • Using either your fingers or the flathead screwdriver, remove the flint by unscrewing the flint spring at the bottom of the lighter.
    • Do this slowly, as the flint will have a tendency to shoot out from the lighter once it is all the way unscrewed.
    • Store the flint in the casing of the Zippo or some other place where it won't be lost.
  3. How to Replace the Wick of a Zippo Lighter: passo 3, immagine 1 di 1
    • Remove the felt pad from the bottom of the Zippo, being careful not to tear it.
    • The flint tube will be in the way, but you can rotate the felt around the tube while pulling out and the felt should come free.
  4. How to Replace the Wick of a Zippo Lighter: passo 4, immagine 1 di 1
    • Remove the cotton pieces from within the lighter and arrange them on your workstation as they were placed in the lighter.
    • If the cotton still feels wet with fuel, allow more time for the fuel to evaporate in a well ventilated area.
    • By keeping the cotton arranged in the same way it was packed into the lighter, you make sure you will be able to place the cotton pieces back in the same way later.
  5. How to Replace the Wick of a Zippo Lighter: passo 5, immagine 1 di 1
    • Remove the spent wick by pulling down with the needle nose pliers through the bottom of the lighter.
  6. How to Replace the Wick of a Zippo Lighter: passo 6, immagine 1 di 1
    • Utilizing the pliers again, feed the wick in through the chimney first.
    • Feed enough through so that the wick doesn't rise above the chimney.
  7. How to Replace the Wick of a Zippo Lighter: passo 7, immagine 1 di 1
    • Begin replacing the cotton, placing the last piece you pulled out in first and doing your best to replace them in the same position they were in before.
    • As you replace the cotton, weave the wick around each piece. This allows more wick to be inside the lighter, increasing its fuel capacity.
  8. How to Replace the Wick of a Zippo Lighter: passo 8, immagine 1 di 1
    • Replace the felt pad by gently pressing it back into place.
  9. How to Replace the Wick of a Zippo Lighter: passo 9, immagine 1 di 1
    • Replace the flint by putting it back down the flint tube and screwing the flint spring back into place.
  10. How to Replace the Wick of a Zippo Lighter: passo 10, immagine 1 di 1
    • Refuel your lighter and place it back into the case. Test it out! If all went well it should light right up. See iFixit's guide to refueling your Zippo if you need any help doing so.
    • Be sure not to spark the lighter while it is out of the case, since closing the case is typically how the flame is put out.
Conclusione
Be sure your work area is clear of any flammable liquids after you finish this replacement.
Altre 21 persone hanno completato questa guida.
Wesley
Membro da: 02/24/15
751 Reputazione
1 Guida realizzata
Cal Poly, Team 24-6, Green Winter 2015 Membro di Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
4 Membri
16 Guide realizzate
5Commenti sulla guida
The wick won't go into that tiny little hole so easily. It won't even get started enough to pull it through the other end. Trying to get it in there, frazzles the end of the wick which further makes it impossible to get it into the hole.
barbaraebj - Replica
Can't u just pull it up to get fresh wick?Call
Terry Geisel -
Like fitting a square peg into a round hole; it just doesn’t fit.
If it’s the lighters fault, shouldn’t they replace it, or do something to fix it?
rburns3 - Replica
Worked just fine- you really have to repack the !&&* out of the cotton around the wick- but it works!
Thanks Wesley! ;)
jac - Replica
On a Zippo-style copy I have there is a small screw that holds a spring bearing on the top lever through which the wick passes. The hole in the centre of the screw seems too small for the standard Zippo wick to pass through. Does anybody know if a smaller diameter wick is available?
David Hughes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 39
Ultimi 30 Giorni: 157
Tutti i Tempi: 38,294
