Salta al contenuto principale
How to Replace the Wheels on an Office Chair
Cosa ti serve
  1. How to Replace the Wheels on an Office Chair, Removing Casters: passo 1, immagine 1 di 1
    • Lay the chair down.
    • If the chair is too heavy to turn upside down, have someone help you do it.
  2. How to Replace the Wheels on an Office Chair: passo 2, immagine 1 di 1
    • Wipe the stem of the caster with a rag or paper towel to remove any dust or debris.
  3. How to Replace the Wheels on an Office Chair: passo 3, immagine 1 di 3 How to Replace the Wheels on an Office Chair: passo 3, immagine 2 di 3 How to Replace the Wheels on an Office Chair: passo 3, immagine 3 di 3
    • Use a flathead screwdriver in between the caster and the base of the chair to pry the wheel out of the socket.
    • Turn the screwdriver gently until the caster starts to move upwards away from the chair.
    • Try rotating the screwdriver at different angles if the caster won't come out.
  4. How to Replace the Wheels on an Office Chair: passo 4, immagine 1 di 3 How to Replace the Wheels on an Office Chair: passo 4, immagine 2 di 3 How to Replace the Wheels on an Office Chair: passo 4, immagine 3 di 3
    • Use a prying tool that is big enough to fit between the caster and over the stem.
    • Gently pull on the caster upwards and it should come off.
  5. How to Replace the Wheels on an Office Chair: passo 5, immagine 1 di 2 How to Replace the Wheels on an Office Chair: passo 5, immagine 2 di 2
    • Measure the wheel's height and length.
    • Once you've done that, purchase your new casters.
    • Large casters(about 3"), are more durable and versatile. Twin-wheel casters are usually used in office settings.
  6. How to Replace the Wheels on an Office Chair: passo 6, immagine 1 di 2 How to Replace the Wheels on an Office Chair: passo 6, immagine 2 di 2
    • Push the caster's stem into the bottom of chair leg.
    • Install the new casters.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 116
Tutti i Tempi: 5,674
