Introduzione
Replacing a worn tip is a simple process that can extend the life of your hiking pole and ensure you stay safe on your adventures. We will show you a step-by-step solution on how to get your hiking pole as good as new!
Cosa ti serve
Prepare all the tools needed for the repair and locate the tip of the hiking pole that needs to be fixed.
In order to protect the pole from scratching, secure it with scotch tape.
Following the direction of the orange arrows, use an adjustable wrench to slide it fast along the hiking pole and push the tip outwards.
Use a hammer to secure the tip in its new position.
Note: only hit it once or twice with a hard tap.
🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
