Salta al contenuto principale
How to Replace the Strings on your Rogue RM-100A A-Style Mandolin
Cosa ti serve
  1. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin, Strings: passo 1, immagine 1 di 2 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin, Strings: passo 1, immagine 2 di 2
    • Lay the Mandolin face up on a flat surface.
    • Start at the headstock of the Mandolin, and unwind the wire string by turning the tuning peg in a clockwise rotation until it becomes loose and easy to remove.
  2. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: passo 2, immagine 1 di 3 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: passo 2, immagine 2 di 3 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: passo 2, immagine 3 di 3
    • At the tailpiece of the Mandolin, use both of your thumbs to apply pressure to push the tailpiece cover away from you.
    • The edge of the tailpiece is a bit sharp. If your fingers hurt, use a small towel or cloth to cushion your thumbs as you push.
  3. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: passo 3, immagine 1 di 2 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: passo 3, immagine 2 di 2
    • Remove the string you are replacing from the tailpiece.
    • The string should be easy to remove.
  4. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: passo 4, immagine 1 di 2 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: passo 4, immagine 2 di 2
    • Insert the new string loop onto the hook.
    • Pull the string up along the bridge onto the fretboard until it reaches the headstock.
  5. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: passo 5, immagine 1 di 2 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: passo 5, immagine 2 di 2
    • Insert the string into the hole of the tuning post all the way through.
  6. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: passo 6, immagine 1 di 3 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: passo 6, immagine 2 di 3 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: passo 6, immagine 3 di 3
    • Loosen the hold of the string.
    • Turn the excess string to the left and pull it under the string.
    • Again, pull the excess string up and over to the left.
    • This creates a sort of hold/knot on the string.
  7. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: passo 7, immagine 1 di 3 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: passo 7, immagine 2 di 3 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: passo 7, immagine 3 di 3
    • Pull the knot.
    • Twist the tuning pegs in a counterclockwise rotation.
    • Twist towards the tailpiece.
  8. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: passo 8, immagine 1 di 1
    • Cut any excess string with pliers.
  9. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: passo 9, immagine 1 di 1
    • Place the tailpiece back by sliding it towards the headstock.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 222
