Salta al contenuto principale
How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta
Cosa ti serve
  1. How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta, Side Mirror Glass: passo 1, immagine 1 di 3 How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta, Side Mirror Glass: passo 1, immagine 2 di 3 How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta, Side Mirror Glass: passo 1, immagine 3 di 3
    • Turn on the accessory power.
    • Twist the mirror adjustment knob to the side you are working on (L for left, R for right).
    • Push the knob so that the mirror will angle towards the car.
    • Turn off the accessory power.
  2. How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: passo 2, immagine 1 di 3 How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: passo 2, immagine 2 di 3 How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: passo 2, immagine 3 di 3
    • Pull the mirror from the exposed back.
    • There will be an audible pop when the mirror is fully detached.
    • Use extra strength to pull out the mirror if needed. Do not worry about breaking the mirror.
  3. How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: passo 3, immagine 1 di 2 How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: passo 3, immagine 2 di 2
    • Pull hard to release the wire from the metal prong, one at a time.
    • If the wire is stuck, wiggle it from side to side.
    • Hold the mirror firmly to avoid accidentally dropping it.
  4. How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: passo 4, immagine 1 di 2 How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: passo 4, immagine 2 di 2
    • Reattach the wires to the metal prongs located on the new mirror.
    • The purple wire goes to the prong furthest from the center of the mirror.
    • The red wire goes to the prong closest to the center of the mirror.
    • Make sure the wires are fully pushed in.
  5. How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: passo 5, immagine 1 di 3 How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: passo 5, immagine 2 di 3 How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: passo 5, immagine 3 di 3
    • Line up the mirror with the housing and push in the central area.
    • The mirror will audibly pop once fully reinstalled.
  6. How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: passo 6, immagine 1 di 1
    • Turn the accessory power on.
    • Using the adjustment knob, move the mirror back to a normal viewing angle.
Conclusione
Follow these instructions for either side mirror. The only difference will be which mirror you adjust using the mirror adjustment knob in step 1.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 149
Tutti i Tempi: 8,432
