Salta al contenuto principale
How to Replace the Headlight in a 2010-2014 Volkswagen Jetta
Cosa ti serve
  1. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta, Headlight: passo 1, immagine 1 di 3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta, Headlight: passo 1, immagine 2 di 3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta, Headlight: passo 1, immagine 3 di 3
    • Turn the ignition fully off and open the hood of your vehicle.
    • The lever to open it is on the left hand side of the pedals. It’ll make a noticeable clunk sound when pulled the first time which releases the first of the two step hood opening procedure.
    • Make your way to the front of the car and push up on the lever underneath the hood to fully open the hood.
    • Use the hood prop rod to hold the hood open for the duration of the repair.
  2. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: passo 2, immagine 1 di 3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: passo 2, immagine 2 di 3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: passo 2, immagine 3 di 3
    • Locate the plastic dust cover behind the burnt headlight and gently remove it. If the cover is stuck, you can use a screwdriver to pop it out.
  3. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: passo 3, immagine 1 di 2 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: passo 3, immagine 2 di 2
    • Once the cover is off, twist the light harness from the fixture in a counter clockwise rotation.
    • Pull the bulb to separate it from the connector.
    • Insert the new bulb in the correct orientation as the previous, and tighten it back into the headlight by rotating it clockwise.
  4. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: passo 4, immagine 1 di 1
    • Reapply the dust cover and close the hood of the vehicle.
  5. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: passo 5, immagine 1 di 1
    • Turn the ignition on and switch on the lights to test the new working headlight.
Conclusione
To replace the other headlight. follow the same instructions.
Seyed-Mohammad Hosseiny
Membro da: 09/22/20
159 Reputazione
1 Guida realizzata
6 Commenti
Am I missing something? Or is there a trick to those tabs to release the bulb?
Dez Petrovic - Replica
They are a pull to release mechanism. no need to undo tabs.
Seyed-Mohammad Hosseiny -
Don’t forget to wear gloves when handling halogen light bulbs!
Where’s the driving lights?
Ted Stoffers - Replica
I installed the new bulb but it still doesn’t work. My neighbor, a retired mechanic came to help and undid both and put back and now, both headlights don’t work. Any other advice?
Emilia Lievano - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 101
Ultimi 30 Giorni: 350
Tutti i Tempi: 21,981
