Salta al contenuto principale
How to Replace the Fishing Line of a Spinning Reel
Cosa ti serve
  1. How to Replace the Fishing Line of a Spinning Reel, Fishing Line: passo 1, immagine 1 di 1
    • Find the recommended line weights on the side of the reel and purchase the specified line.
    • The side of this reel reads lbs/yrds 6/390, 8/320, or 10,200 so use 6, 8, or 10 pound fishing line.
  2. How to Replace the Fishing Line of a Spinning Reel: passo 2, immagine 1 di 3 How to Replace the Fishing Line of a Spinning Reel: passo 2, immagine 2 di 3 How to Replace the Fishing Line of a Spinning Reel: passo 2, immagine 3 di 3
    • Flip up the metal bail on the spinning reel.
    • Remove the old line by pulling it off the top of the reel.
  3. How to Replace the Fishing Line of a Spinning Reel: passo 3, immagine 1 di 3 How to Replace the Fishing Line of a Spinning Reel: passo 3, immagine 2 di 3 How to Replace the Fishing Line of a Spinning Reel: passo 3, immagine 3 di 3
    • Feed the end of the new line through the first eyelet of the fishing rod.
    • Tie a single overhand knot towards the end of the line.
  4. How to Replace the Fishing Line of a Spinning Reel: passo 4, immagine 1 di 3 How to Replace the Fishing Line of a Spinning Reel: passo 4, immagine 2 di 3 How to Replace the Fishing Line of a Spinning Reel: passo 4, immagine 3 di 3
    • With the bail still up, wrap the line around the reel and tie a double overhand knot.
    • Tighten the line up to the first knot made in the previous step.
  5. How to Replace the Fishing Line of a Spinning Reel: passo 5, immagine 1 di 1
    • Use utility scissors to clip the excess line near the base of the reel.
  6. How to Replace the Fishing Line of a Spinning Reel: passo 6, immagine 1 di 1
    • Place the new spool so it is facing up to prevent line twist.
  7. How to Replace the Fishing Line of a Spinning Reel: passo 7, immagine 1 di 3 How to Replace the Fishing Line of a Spinning Reel: passo 7, immagine 2 di 3 How to Replace the Fishing Line of a Spinning Reel: passo 7, immagine 3 di 3
    • Flip the bail down and slowly reel the line, keeping light tension using your finger.
    • Continue reeling until there is roughly an 1/8th of an inch of radial space left on the reel.
    • Do not overfill the reel with line. This may cause tangles.
  8. How to Replace the Fishing Line of a Spinning Reel: passo 8, immagine 1 di 3 How to Replace the Fishing Line of a Spinning Reel: passo 8, immagine 2 di 3 How to Replace the Fishing Line of a Spinning Reel: passo 8, immagine 3 di 3
    • Use utility scissors to cut the line free of the spool.
    • Clip the free end into the line holder on the side of the reel.
Conclusione
Stefan Venne
Membro da: 01/26/23
184 Reputazione
1 Guida realizzata
UC Davis, Team 2-13, Morris Winter 2023 Membro di UC Davis, Team 2-13, Morris Winter 2023
UCD-MORRIS-W23S2G13
1 Membro
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 37
Tutti i Tempi: 1,054
