Salta al contenuto principale
How to Replace the Bearings on a Street Skateboard
Cosa ti serve
  1. How to Replace the Bearings on a Street Skateboard, Bearings: passo 1, immagine 1 di 1
    • Lay the skateboard on its side so that bearings and axles are facing toward you.
  2. How to Replace the Bearings on a Street Skateboard: passo 2, immagine 1 di 3 How to Replace the Bearings on a Street Skateboard: passo 2, immagine 2 di 3 How to Replace the Bearings on a Street Skateboard: passo 2, immagine 3 di 3
    • Using a skateboard tool or wrench, unscrew the axle nut above the wheel.
    • Remove the wheel from the axle.
  3. How to Replace the Bearings on a Street Skateboard: passo 3, immagine 1 di 3 How to Replace the Bearings on a Street Skateboard: passo 3, immagine 2 di 3 How to Replace the Bearings on a Street Skateboard: passo 3, immagine 3 di 3
    • Position the wheel halfway on the end of the axle.
    • Holding the skateboard down with your other hand, use the end of the axle to pry the bearing out.
  4. How to Replace the Bearings on a Street Skateboard: passo 4, immagine 1 di 2 How to Replace the Bearings on a Street Skateboard: passo 4, immagine 2 di 2
    • Set the old bearing aside.
    • Repeat the previous step with the other side of the wheel to remove the other bearing.
  5. How to Replace the Bearings on a Street Skateboard: passo 5, immagine 1 di 3 How to Replace the Bearings on a Street Skateboard: passo 5, immagine 2 di 3 How to Replace the Bearings on a Street Skateboard: passo 5, immagine 3 di 3
    • Place a fresh bearing face down (colored side down) onto the axle, and push the wheel down against the metal truck to pop the new bearing in.
    • Hold the skateboard in place with your other hand.
  6. How to Replace the Bearings on a Street Skateboard: passo 6, immagine 1 di 1
    • Take the wheel off.
    • Add another fresh bearing onto the axle.
    • Repeat the previous step for the other side of the wheel by pushing the wheel down to pop the bearing in.
  7. How to Replace the Bearings on a Street Skateboard: passo 7, immagine 1 di 3 How to Replace the Bearings on a Street Skateboard: passo 7, immagine 2 di 3 How to Replace the Bearings on a Street Skateboard: passo 7, immagine 3 di 3
    • Place washer(s) onto the axle and then screw the axle nut back on.
    • Repeat steps as needed with other wheels.
Linea Traguardo
Maxen Hamelynck
Membro da: 01/21/25
157 Reputazione
1 Guida realizzata
UC Davis, Team 1-4, Morris Winter 2025 Membro di UC Davis, Team 1-4, Morris Winter 2025
UCD-MORRIS-W25S1G4
3 Membri
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 96
