Salta al contenuto principale
TI-Nspire CX Battery Replacement
Cosa ti serve
  1. TI-Nspire CX Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Use a Phillips #0 screwdriver to loosen the captive screws on the back plate of the calculator.
    • The screws do not come all the way out. Simply twist them until you are able to remove the back plate.
  2. TI-Nspire CX Battery Replacement: passo 2, immagine 1 di 2 TI-Nspire CX Battery Replacement: passo 2, immagine 2 di 2
    • Remove the back plate using the spudger or by hand.
  3. TI-Nspire CX Battery Replacement: passo 3, immagine 1 di 3 TI-Nspire CX Battery Replacement: passo 3, immagine 2 di 3 TI-Nspire CX Battery Replacement: passo 3, immagine 3 di 3
    • Carefully disconnect and remove the old battery.
    • Unhook the wire from the tab.
    • Carefully pull out the connector.
    • Grip the wire close to the top and pull away.
  4. TI-Nspire CX Battery Replacement: passo 4, immagine 1 di 1
    • Plug in the new battery.
    • Make sure to put the wire back in the same way. You should see 4 metal connections on top
  5. TI-Nspire CX Battery Replacement: passo 5, immagine 1 di 1
    • Position the new battery and tuck the wire under the tab.
  6. TI-Nspire CX Battery Replacement: passo 6, immagine 1 di 1
    • Replace the back plate and the 2 screws.
Conclusione
Now charge your calculator and power it up. If replacing the battery does not solve your problem, it may be a problem with your charging cord or the internal sockets.
Altre 9 persone hanno completato questa guida.
Jim Kerman
Membro da: 02/24/15
314 Reputazione
1 Guida realizzata
Cal Poly, Team 24-2, Green Winter 2015 Membro di Cal Poly, Team 24-2, Green Winter 2015
CPSU-GREEN-W15S24G2
4 Membri
4 Guide realizzate
2 Commenti
Hi. I own a TI Nspire CX CAS. I’ve had it for 5 years now and the battery’s been screwy for the past few years. I just ordered a new battery with good reviews from amazon. I’m worried that if I take out the battery my documents and other saved settings will be deleted. Does removing the battery delete anything? I have the modded operating system for my oldschool gameboy games, so I really don’t want to lose my games and settings, as the laptop I used years ago to put the games on there has been broken. I would really appreciate any help. Thank you.
G Reod - Replica
Hola Amigo. Pudiste solucionar?
Armando02 -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 135
Tutti i Tempi: 16,219
