Introduzione
Replacing the battery of the Armitron watch will require disassembling most of the watch.
Cosa ti serve
Pinch the metal tab.
Pull the chip up and out.
How do you short out the battery. Confusing but nice watch. Can you help???? Plz!!!!
Altre 12 persone hanno completato questa guida.
9 Commenti
what about the after battery replacement short circuit to reset it? that’s the hard part that totally is unclear!
With a magnifying glass there is RESET written with a small diamond [THE ARROW] at one part of the back under the battery, On the side there is a slot that you put a piece of flat metal, small tipped screwdriver, into it. This will touch the contacts inside to reset the watch.
what about the post battery replacement short circuit reset?! that’s the hard part that’s completely unclear and confusing!
my comments don’t seem to be working.
I agree that these instructions are very deficient when describing how to reset the battery. I just spent 1/2 hour resetting an Amitron MD0699. One is supposed to bridge about a 2 mm gap between 2 vertical bands of metal. The space to approach this is very small. A normal paper clip tip is too narrow for this purpose. A large metallic paper clip tip might work, but you will have to prove that the metal is conductive. My micro screwdriver set didn’t work; I didn’t realize the metal was non conductive til I tested it with an electrometer. In the end, the electrometer tip was just the right size. I reassuring little chime rang when the reset occurs. All these little fine points would have made the original post useful.
I took the whole watch assembly out of the case and was able to short out the 2 tabs with a piece of stripped 16 ga stranded copper wire.
My particular Armitron had a VERY VAGUE reset diagram. A hole next to the battery had an imprinted arrow reading “RESET.” I broke off a large metal paper clip, stuck it in the hole and then shorted over to the new battery with the rest of the paper clip to reset.
Paul M 3-12-19
Lori H. -1/29/20 - I have a Armitron MD0699. My battery died. I can not find any instructions on HOW TO take the back off to replace the battery. There is NO WAY to remove the back! HELP!!!
Can any one tell me how to set the light on watch
