Salta al contenuto principale
How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock
Cosa ti serve
  1. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: passo 1, immagine 1 di 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: passo 1, immagine 2 di 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: passo 1, immagine 3 di 3
    • Remove the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
    • Left side
    • Right side
    • Bottom
  2. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 2, immagine 1 di 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 2, immagine 2 di 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 2, immagine 3 di 3
    • Remove the faceplate from the lock mechanism by pulling straight out.
  3. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 3, immagine 1 di 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 3, immagine 2 di 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 3, immagine 3 di 3
    • Remove the battery pack from the lock mechanism by pulling straight up.
  4. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 4, immagine 1 di 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 4, immagine 2 di 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 4, immagine 3 di 3
    • Remove the batteries from the battery pack.
  5. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 5, immagine 1 di 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 5, immagine 2 di 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 5, immagine 3 di 3
    • Insert new batteries into the battery pack.
  6. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 6, immagine 1 di 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 6, immagine 2 di 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 6, immagine 3 di 3
    • Insert the battery pack back into the lock mechanism by pushing straight down.
    • Make sure the label is facing outward.
  7. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 7, immagine 1 di 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 7, immagine 2 di 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 7, immagine 3 di 3
    • Reattach the faceplate to the lock mechanism by pushing straight in.
  8. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 8, immagine 1 di 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 8, immagine 2 di 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: passo 8, immagine 3 di 3
    • Reattach the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
    • Bottom
    • Right side
    • Left side
Conclusione
That's it! Your Kwikset Home Connect 620 Smart Lock should now be working properly.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 39
Tutti i Tempi: 161
