Salta al contenuto principale
How to Replace the Arm of Standard Hinge Eyeglasses
Cosa ti serve
  1. How to Replace the Arm of Standard Hinge Eyeglasses, Eyeglasses Arm: passo 1, immagine 1 di 2 How to Replace the Arm of Standard Hinge Eyeglasses, Eyeglasses Arm: passo 1, immagine 2 di 2
    • Remove the screw holding the broken arm by turning it counterclockwise.
  2. How to Replace the Arm of Standard Hinge Eyeglasses: passo 2, immagine 1 di 1
    • Carefully set the screw aside and discard the broken arm.
  3. How to Replace the Arm of Standard Hinge Eyeglasses: passo 3, immagine 1 di 1
    • Thoroughly clean the screw and the connecting hinge using the cleaning cloth to remove any dirt or buildup.
  4. How to Replace the Arm of Standard Hinge Eyeglasses: passo 4, immagine 1 di 2 How to Replace the Arm of Standard Hinge Eyeglasses: passo 4, immagine 2 di 2
    • Align the joints of the new arm with the joint connected to the frame.
    • The frame joint should be in between the two joints of the arm.
  5. How to Replace the Arm of Standard Hinge Eyeglasses: passo 5, immagine 1 di 3 How to Replace the Arm of Standard Hinge Eyeglasses: passo 5, immagine 2 di 3 How to Replace the Arm of Standard Hinge Eyeglasses: passo 5, immagine 3 di 3
    • Insert the screw in the hinge and lightly tighten by turning the screw clockwise.
    • Make sure all parts are aligned and that the new arm is not angled.
    • You may want to put the glasses on to make sure the arm is positioned properly.
  6. How to Replace the Arm of Standard Hinge Eyeglasses: passo 6, immagine 1 di 1
    • Once aligned, fully tighten the screw.
    • You may need to make adjustments to the tightness of the arm. Tighten (turn clockwise) or loosen (turn counterclockwise) the screw until you have a comfortable fit.
Linea Traguardo
Mariam
Membro da: 01/16/23
163 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 16
Ultimi 7 Giorni: 89
Ultimi 30 Giorni: 260
Tutti i Tempi: 2,398
