Salta al contenuto principale
How to Replace and Install Ceiling Light Fixtures
Cosa ti serve
  1. How to Replace and Install Ceiling Light Fixtures, Ceiling Light Fixture: passo 1, immagine 1 di 1
    • Turn the main power off.
    • Ensure that the circuit breaker is off to avoid electrocution. Optional use of a circuit tester to verify the power is off.
    Chiedi a FixBot
  2. How to Replace and Install Ceiling Light Fixtures: passo 2, immagine 1 di 2 How to Replace and Install Ceiling Light Fixtures: passo 2, immagine 2 di 2
    • Remove the cover of the old light fixture.
    • Unscrew all lightbulbs.
    Chiedi a FixBot
  3. How to Replace and Install Ceiling Light Fixtures: passo 3, immagine 1 di 3 How to Replace and Install Ceiling Light Fixtures: passo 3, immagine 2 di 3 How to Replace and Install Ceiling Light Fixtures: passo 3, immagine 3 di 3
    • Remove the screws holding the old light fixture's housing with a screwdriver
    • Carefully pull the old light fixture and its wiring down.
    • Without the screws, the housing will no longer be attached to the ceiling. Hold the housing until it hangs gently to avoid injury.
    Chiedi a FixBot
  4. How to Replace and Install Ceiling Light Fixtures: passo 4, immagine 1 di 3 How to Replace and Install Ceiling Light Fixtures: passo 4, immagine 2 di 3 How to Replace and Install Ceiling Light Fixtures: passo 4, immagine 3 di 3
    • Remove the old wire connectors and untwist the wires.
    • The old light fixture will completely detach. Prevent it from falling by holding onto the housing.
    Chiedi a FixBot
  5. How to Replace and Install Ceiling Light Fixtures: passo 5, immagine 1 di 3 How to Replace and Install Ceiling Light Fixtures: passo 5, immagine 2 di 3 How to Replace and Install Ceiling Light Fixtures: passo 5, immagine 3 di 3
    • Match the new ceiling light wiring to your home’s existing wires.
    • Link each pair with wire connectors by placing the exposed ends inside, and twisting down until tight.
    • If your home does not have a corresponding grounding wire to connect to:
    • You must connect the fixture ground wire to the ground screw of the ceiling crossbar.
    • Or you must connect the fixture ground wire to the house ground wire (the bare copper wire without any insulation)
    Chiedi a FixBot
  6. How to Replace and Install Ceiling Light Fixtures: passo 6, immagine 1 di 3 How to Replace and Install Ceiling Light Fixtures: passo 6, immagine 2 di 3 How to Replace and Install Ceiling Light Fixtures: passo 6, immagine 3 di 3
    • Find the proper alignment for the holes of the new housing with the ceiling's mounting bar.
    • Carefully place all wiring into the electrical box or empty space within the ceiling.
    • Secure the housing to the ceiling with two screws, tightening them firmly with a screwdriver.
    Chiedi a FixBot
  7. How to Replace and Install Ceiling Light Fixtures: passo 7, immagine 1 di 1
    • Attach the cover and/or lightbulbs of the new light fixture.
    Chiedi a FixBot
  8. How to Replace and Install Ceiling Light Fixtures: passo 8, immagine 1 di 2 How to Replace and Install Ceiling Light Fixtures: passo 8, immagine 2 di 2
    • Turn the main power back on and watch as your handiwork lights up the room!
    Chiedi a FixBot
Conclusione
Alexandria S
Membro da: 02/08/24
184 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 22
Ultimi 30 giorni: 112
Tutti i Tempi: 2,088
