Salta al contenuto principale
How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler
Cosa ti serve
  1. How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler, Zipper Tab: passo 1, immagine 1 di 2 How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler, Zipper Tab: passo 1, immagine 2 di 2
    • You'll need two sections of leather: a thicker strip for the pull tab, and a thinner strip for the loop that attaches to the split ring.
    • On a piece of leather, use a pencil and ruler to mark the lines for cutting.
    • The height of the thicker strip is 2 inches, and the length is 1 inch.
    • The height of the thinner strip is 1 1/2 inches, and the length is 1/2 inches.
  2. How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 2, immagine 1 di 3 How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 2, immagine 2 di 3 How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 2, immagine 3 di 3
    • Using heavy duty scissors, cut out the outline of the zipper tab.
  3. How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 3, immagine 1 di 3 How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 3, immagine 2 di 3 How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 3, immagine 3 di 3
    • Use an awl to pierce a hole into the top of the thinner strip.
    • This hole is for the rivet.
    • Take care not to stab yourself as you puncture the leather. It is better to pierce it slowly to reduce the risk of injury.
  4. How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 4, immagine 1 di 2 How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 4, immagine 2 di 2
    • Pierce the thicker part of the strip near the top using the same technique.
  5. How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 5, immagine 1 di 3 How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 5, immagine 2 di 3 How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 5, immagine 3 di 3
    • Insert one of the rivet caps into the hole of the thinner strip.
    • Insert the other cap of the rivet into the hole of the thicker strip.
  6. How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 6, immagine 1 di 3 How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 6, immagine 2 di 3 How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 6, immagine 3 di 3
    • Slip the split ring through the thinner strip and pull it towards the thicker strip.
    • Connect the two rivets together to create a loop around the split ring.
  7. How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 7, immagine 1 di 2 How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 7, immagine 2 di 2
    • Gently hammer the two rivets together so that they stay connected.
    • If you hit the rivet too hard with the hammer it will damage the rivet and make it unusable.
  8. How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 8, immagine 1 di 2 How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 8, immagine 2 di 2
    • Flip it over and gently hammer the other side of the rivet to seal the connection.
  9. How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 9, immagine 1 di 3 How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 9, immagine 2 di 3 How to Replace a Zipper Tab for a Yeti Hopper Flip Soft Cooler: passo 9, immagine 3 di 3
    • Open the split ring and attach it to the zipper slider.
    • Test out the zipper by pulling it by the leather tab and zipping the cooler closed.
Linea Traguardo
Liam Lansangan
Membro da: 02/27/24
169 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 59
Tutti i Tempi: 118
