Salta al contenuto principale
How to Replace a Window Arm for an Out-Swinging Casement Window
Cosa ti serve
  1. How to Replace a Window Arm for an Out-Swinging Casement Window, Window Arm: passo 1, immagine 1 di 2 How to Replace a Window Arm for an Out-Swinging Casement Window, Window Arm: passo 1, immagine 2 di 2
    • Unlock the window lock by flipping both switches up until they are pointed horizontally outwards, facing the user.
  2. How to Replace a Window Arm for an Out-Swinging Casement Window: passo 2, immagine 1 di 3 How to Replace a Window Arm for an Out-Swinging Casement Window: passo 2, immagine 2 di 3 How to Replace a Window Arm for an Out-Swinging Casement Window: passo 2, immagine 3 di 3
    • Pull open all four metal screen latches holding the window screen in place.
    • Place hands on both sides of the screen and lift upwards to remove it.
    • In some cases only two screen latches need to be unlocked for the screen to become loose enough to remove.
  3. How to Replace a Window Arm for an Out-Swinging Casement Window: passo 3, immagine 1 di 3 How to Replace a Window Arm for an Out-Swinging Casement Window: passo 3, immagine 2 di 3 How to Replace a Window Arm for an Out-Swinging Casement Window: passo 3, immagine 3 di 3
    • Turn the window handle clockwise to open the window.
  4. How to Replace a Window Arm for an Out-Swinging Casement Window: passo 4, immagine 1 di 1
    • Use a flathead screwdriver in a clockwise direction to remove the 2.11 mm screw from the bottom of the window handle.
  5. How to Replace a Window Arm for an Out-Swinging Casement Window: passo 5, immagine 1 di 3 How to Replace a Window Arm for an Out-Swinging Casement Window: passo 5, immagine 2 di 3 How to Replace a Window Arm for an Out-Swinging Casement Window: passo 5, immagine 3 di 3
    • Turn the loosened window handle in either direction to remove it.
  6. How to Replace a Window Arm for an Out-Swinging Casement Window: passo 6, immagine 1 di 3 How to Replace a Window Arm for an Out-Swinging Casement Window: passo 6, immagine 2 di 3 How to Replace a Window Arm for an Out-Swinging Casement Window: passo 6, immagine 3 di 3
    • Detach the window arm from the track running underneath the window.
    • In most cases window arm has already been detached, so this step would be skipped.
  7. How to Replace a Window Arm for an Out-Swinging Casement Window: passo 7, immagine 1 di 3 How to Replace a Window Arm for an Out-Swinging Casement Window: passo 7, immagine 2 di 3 How to Replace a Window Arm for an Out-Swinging Casement Window: passo 7, immagine 3 di 3
    • Using a Square #0 screwdriver, remove the four 25.4 mm screws placed on the outside of the window sill.
  8. How to Replace a Window Arm for an Out-Swinging Casement Window: passo 8, immagine 1 di 3 How to Replace a Window Arm for an Out-Swinging Casement Window: passo 8, immagine 2 di 3 How to Replace a Window Arm for an Out-Swinging Casement Window: passo 8, immagine 3 di 3
    • Pull the body of the window operator which when removed will vacate a slot.
    • Pull the window arm diagonally through the slot.
  9. How to Replace a Window Arm for an Out-Swinging Casement Window: passo 9, immagine 1 di 2 How to Replace a Window Arm for an Out-Swinging Casement Window: passo 9, immagine 2 di 2
    • Insert the new window operator into the slot, ensuring it is tightly fit into place.
    • Attach a replacement window arm to the track on the bottom of the window panel.
Conclusione
Nabil Patel
Membro da: 01/08/21
169 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 92
Tutti i Tempi: 1,504
