Salta al contenuto principale
How to Replace a Valve Spring on a Trumpet
Cosa ti serve
  1. How to Replace a Valve Spring on a Trumpet, valve spring: passo 1, immagine 1 di 2 How to Replace a Valve Spring on a Trumpet, valve spring: passo 1, immagine 2 di 2
    • To pull out the valve, first twist the top of the valve open counterclockwise to detach it from the rest of the valve.
    • Pull the valve out of the trumpet.
  2. How to Replace a Valve Spring on a Trumpet: passo 2, immagine 1 di 2 How to Replace a Valve Spring on a Trumpet: passo 2, immagine 2 di 2
    • Near the top of the valve, twist the top part of the screw compartment off to access the screw.
    • Pull the old spring out and replace with the new one.
    • Reassemble the valve the same way it came apart.
  3. How to Replace a Valve Spring on a Trumpet: passo 3, immagine 1 di 2 How to Replace a Valve Spring on a Trumpet: passo 3, immagine 2 di 2
    • Before inserting the valve back into the trumpet, put enough valve oil on the valve so that that the surface is wet, but not dripping.
    • Insert the valve into the trumpet, and screw in the top clockwise.
    • Be sure to grasp the top of the valve and twist until a clicking sound is heard and the valve locks in place to ensure that the trumpet is ready for playing.
Conclusione
Isaac Trotta
Membro da: 02/24/15
125 Reputazione
1 Guida realizzata
Cal Poly, Team 23-4, Green Winter 2015 Membro di Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 Membri
15 Guide realizzate
Un commento
I cannot manage to take out my valve it is so hard It’s a brand new trumpet sound like come out and then I don’t have valve oil
Flavio - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 39
Tutti i Tempi: 8,269
