Salta al contenuto principale
How to Replace a Toilet's Shut-Off Valve
Cosa ti serve
  1. How to Replace a Toilet's Shut-Off Valve, Shut-Off Valve: passo 1, immagine 1 di 2 How to Replace a Toilet's Shut-Off Valve, Shut-Off Valve: passo 1, immagine 2 di 2
    • Locate the water main line (typically found in your basement).
    • Turn off the water main line by rotating the knob clockwise.
  2. How to Replace a Toilet's Shut-Off Valve: passo 2, immagine 1 di 2 How to Replace a Toilet's Shut-Off Valve: passo 2, immagine 2 di 2
    • Go to the lowest level of your house and turn the faucet on at any sink.
    • Keep the faucet running until it stops spewing water. If the faucet doesn't stop, you likely turned the wrong valve in Step 1.
  3. How to Replace a Toilet's Shut-Off Valve: passo 3, immagine 1 di 1
    • Flush the toilet (the one that needs the valve to be replaced).
  4. How to Replace a Toilet's Shut-Off Valve: passo 4, immagine 1 di 2 How to Replace a Toilet's Shut-Off Valve: passo 4, immagine 2 di 2
    • Turn the toilet shut off valve counter clockwise.
  5. How to Replace a Toilet's Shut-Off Valve: passo 5, immagine 1 di 2 How to Replace a Toilet's Shut-Off Valve: passo 5, immagine 2 di 2
    • Using the wrench, disconnect the tank hose from the pipe by turning the wrench clockwise until the hose is completely disconnected from the pipe.
  6. How to Replace a Toilet's Shut-Off Valve: passo 6, immagine 1 di 2 How to Replace a Toilet's Shut-Off Valve: passo 6, immagine 2 di 2
    • Rotate the toilet shut-off valve clockwise with the wrench until the valve comes off from the pipe.
    • Slide the new valve onto the pipe and tighten the valve onto the pipe with the wrench.
    • Using the wrench reconnect the hose to the pipe by rotating the wrench counter clockwise.
    • Turn the water main on rotating the knob counter clockwise.
Linea Traguardo
Jayden Scott-Douglas
Membro da: 01/08/21
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 37
Tutti i Tempi: 3,716
