Salta al contenuto principale
How to Replace a Tail Light for a 2011-2015 Ford Explorer
Cosa ti serve
  1. How to Replace a Tail Light for a 2011-2015 Ford Explorer, Tail Light Bulbs: passo 1, immagine 1 di 2 How to Replace a Tail Light for a 2011-2015 Ford Explorer, Tail Light Bulbs: passo 1, immagine 2 di 2
    • Lift and open the rear cargo door.
  2. How to Replace a Tail Light for a 2011-2015 Ford Explorer: passo 2, immagine 1 di 1
    • Locate the two plastic screw covers that are adjacent to the rear light covers.
  3. How to Replace a Tail Light for a 2011-2015 Ford Explorer: passo 3, immagine 1 di 1
    • Using a flathead screwdriver, pry out both plastic screw covers.
  4. How to Replace a Tail Light for a 2011-2015 Ford Explorer: passo 4, immagine 1 di 1
    • Once covers are removed, there will be an 8 mm hex head screw located beneath each cover.
  5. How to Replace a Tail Light for a 2011-2015 Ford Explorer: passo 5, immagine 1 di 1
    • Using an 8 mm Deep Socket Wrench, remove both of the 20 mm (length) hex-head screws.
  6. How to Replace a Tail Light for a 2011-2015 Ford Explorer: passo 6, immagine 1 di 2 How to Replace a Tail Light for a 2011-2015 Ford Explorer: passo 6, immagine 2 di 2
    • Gently pull the tail light cover from the car.
    • You may have to gently play with the cover by moving it back and forth in order to pry it loose form the car.
  7. How to Replace a Tail Light for a 2011-2015 Ford Explorer: passo 7, immagine 1 di 1
    • Once removed, the bulb sockets will be located on the inside portion of the tail light cover.
  8. How to Replace a Tail Light for a 2011-2015 Ford Explorer: passo 8, immagine 1 di 1
    • Turn the bulb socket about one quarter turn in a counterclockwise direction.
    • After it is turned, gently pull and remove the bulb socket from the tail light cover.
  9. How to Replace a Tail Light for a 2011-2015 Ford Explorer: passo 9, immagine 1 di 1
    • Gently remove the bulb from the bulb socket.
  10. How to Replace a Tail Light for a 2011-2015 Ford Explorer: passo 10, immagine 1 di 1
    • Gently place the new bulb in the bulb socket.
Conclusione
Altre 8 persone hanno completato questa guida.
Michael Lynch
Membro da: 09/29/15
317 Reputazione
1 Guida realizzata
Cal Poly, Team 14-4, Green Fall 2015 Membro di Cal Poly, Team 14-4, Green Fall 2015
CPSU-GREEN-F15S14G4
5 Membri
16 Guide realizzate
Un commento
That's not the tail lights that is the turn signal and back up lights.
Djay Glass - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 116
Tutti i Tempi: 22,120
