Salta al contenuto principale
How to Replace a Skateboard Deck
Cosa ti serve
  1. How to Replace a Skateboard Deck, Deck: passo 1, immagine 1 di 1
    • Use the 3/8" socket to take off the nut
    • Use the phillips side to hold the screw in place.
    • Remove the nut
    • Repeat for all four nuts on the truck
    • Repeat for the second truck
  2. How to Replace a Skateboard Deck: passo 2, immagine 1 di 2 How to Replace a Skateboard Deck: passo 2, immagine 2 di 2
    • Remove both trucks from the board
    • Remove all 8 screws
  3. How to Replace a Skateboard Deck: passo 3, immagine 1 di 3 How to Replace a Skateboard Deck: passo 3, immagine 2 di 3 How to Replace a Skateboard Deck: passo 3, immagine 3 di 3
    • Line up the grip with the board
    • Ensure it covers the entirety of the board and hangs over the edge
    • Peel the back off at one end enough to reveal the sticky side.
    • Expose about four inches
    • Attach the peeled side to one end of the board
    • Press the grip onto the board slowly and work your way across the board
    • Ensure that there is no air bubbles forming when applying the grip
  4. How to Replace a Skateboard Deck: passo 4, immagine 1 di 2 How to Replace a Skateboard Deck: passo 4, immagine 2 di 2
    • Use the phillips head screwdriver to trace the edge of the board
    • Ensure it can be seen all the way around the board
  5. How to Replace a Skateboard Deck: passo 5, immagine 1 di 1
    • Trim the grip along the trace you made with the box cutter
    • Use long and smooth motions for straight trims
    • Trim up the jagged edges left on the grip on the edge of the board
  6. How to Replace a Skateboard Deck: passo 6, immagine 1 di 1
    • Sand the edges with the left over grip
    • This is to ensure the grip fully applies to the board
  7. How to Replace a Skateboard Deck: passo 7, immagine 1 di 2 How to Replace a Skateboard Deck: passo 7, immagine 2 di 2
    • Poke a hole with the screw from the bottom of the deck
    • Remove the screw
    • Insert it through the top on the deck
    • Repeat for all 4 holes
    • Repeat on the opposite side with the other truck
  8. How to Replace a Skateboard Deck: passo 8, immagine 1 di 3 How to Replace a Skateboard Deck: passo 8, immagine 2 di 3 How to Replace a Skateboard Deck: passo 8, immagine 3 di 3
    • Use the 3/8" socket to screw on the nut
    • The hangar should face outwards
    • Tighten them until they're snug
    • Overtightening can damage the deck
Linea Traguardo
Dylan Norris
Membro da: 10/06/22
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 792
