Introduzione
This guide will show you how to replace a damaged RG-6 Coaxial cable connector.
When watching cable TV, people often see interrupted or irregular pictures. Poor picture quality is an indicator that the coaxial cable is not properly assembled or is causing issues with the electric signal going into the cable. To fix this issue, replace the coaxial cable connector.
During my four years of work at Charter Communications, also known as Spectrum, I had the opportunity to learn, apply and succeed in replacing broken coaxial cables. This guide will help you replace a coaxial cable connector successfully.
Cosa ti serve
Use a cable cutter to cut your desired length of cable.
Cut both ends of the cable at 90 degrees, meaning the cutter and the cable should be positioned at 90 degree of one another.
Use a RG-6 coaxial cable stripper to strip each end of the cable.
Position the end of cable inside the stripper and rotate it around the cable in a clockwise motion three times. Then, do one full turn counterclockwise.
Repeat this on the other end of the cable.
After stripping the ends, remove the two pieces of shield cable from the cable.
