Salta al contenuto principale
How to Replace a Nequare Cordless Vacuum S182 Filter
  1. How to Replace a Nequare Cordless Vacuum S182 Filter, Filter: passo 1, immagine 1 di 2 How to Replace a Nequare Cordless Vacuum S182 Filter, Filter: passo 1, immagine 2 di 2
    • Locate the black button to release the white motor unit from the rest of the vacuum cleaner.
  2. How to Replace a Nequare Cordless Vacuum S182 Filter: passo 2, immagine 1 di 2 How to Replace a Nequare Cordless Vacuum S182 Filter: passo 2, immagine 2 di 2
    • Hold down the black button to remove the white motor unit above and gently pull the motor unit upwards.
  3. How to Replace a Nequare Cordless Vacuum S182 Filter: passo 3, immagine 1 di 2 How to Replace a Nequare Cordless Vacuum S182 Filter: passo 3, immagine 2 di 2
    • Press the release button at the side of the dust canister to dispose of the debris.
    • Be sure to hold the the canister over a garbage can to avoid a spill.
  4. How to Replace a Nequare Cordless Vacuum S182 Filter: passo 4, immagine 1 di 3 How to Replace a Nequare Cordless Vacuum S182 Filter: passo 4, immagine 2 di 3 How to Replace a Nequare Cordless Vacuum S182 Filter: passo 4, immagine 3 di 3
    • After emptying the debris, hold down the black button, then twist and pull the canister out.
  5. How to Replace a Nequare Cordless Vacuum S182 Filter: passo 5, immagine 1 di 2 How to Replace a Nequare Cordless Vacuum S182 Filter: passo 5, immagine 2 di 2
    • Take the filter out and dispose of it.
  6. How to Replace a Nequare Cordless Vacuum S182 Filter: passo 6, immagine 1 di 2 How to Replace a Nequare Cordless Vacuum S182 Filter: passo 6, immagine 2 di 2
    • Remove the black part by gently pushing from inside of the canister.
  7. How to Replace a Nequare Cordless Vacuum S182 Filter: passo 7, immagine 1 di 2 How to Replace a Nequare Cordless Vacuum S182 Filter: passo 7, immagine 2 di 2
    • Clean both the canister and the black part either by rinsing it out or using a wash cloth.
  8. How to Replace a Nequare Cordless Vacuum S182 Filter: passo 8, immagine 1 di 3 How to Replace a Nequare Cordless Vacuum S182 Filter: passo 8, immagine 2 di 3 How to Replace a Nequare Cordless Vacuum S182 Filter: passo 8, immagine 3 di 3
    • Put the black part back into the canister and put in the new filter.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 45
Tutti i Tempi: 1,272
