Salta al contenuto principale
How to Replace a Leaking Set Screw Tub Spout
Cosa ti serve
  1. How to Replace a Leaking Set Screw Tub Spout, Set Screw Tub Spout: passo 1, immagine 1 di 2 How to Replace a Leaking Set Screw Tub Spout, Set Screw Tub Spout: passo 1, immagine 2 di 2
    • Cover the shower drain with a plug or a piece of cloth to prevent the screw from falling in.
    • Make sure the water is turned off.
  2. How to Replace a Leaking Set Screw Tub Spout: passo 2, immagine 1 di 3 How to Replace a Leaking Set Screw Tub Spout: passo 2, immagine 2 di 3 How to Replace a Leaking Set Screw Tub Spout: passo 2, immagine 3 di 3
    • Using an 5/32" Allen key, loosen the screw located under the spout.
    • You should not remove the screw. But instead, untighten the screw until it's loose.
  3. How to Replace a Leaking Set Screw Tub Spout: passo 3, immagine 1 di 3 How to Replace a Leaking Set Screw Tub Spout: passo 3, immagine 2 di 3 How to Replace a Leaking Set Screw Tub Spout: passo 3, immagine 3 di 3
    • Gently pull out the spout using your hand and set it aside somewhere.
    • Protip: Wiggle the spout side to side to help pull it out.
  4. How to Replace a Leaking Set Screw Tub Spout: passo 4, immagine 1 di 3 How to Replace a Leaking Set Screw Tub Spout: passo 4, immagine 2 di 3 How to Replace a Leaking Set Screw Tub Spout: passo 4, immagine 3 di 3
    • Using sandpaper or a sponge, gently rub and clean the pipe.
    • This allows for the new set screw tub spout to easily slip on.
    • Once you have finished cleaning the pipe, wipe off the dust with a piece of cloth or paper towel.
  5. How to Replace a Leaking Set Screw Tub Spout: passo 5, immagine 1 di 3 How to Replace a Leaking Set Screw Tub Spout: passo 5, immagine 2 di 3 How to Replace a Leaking Set Screw Tub Spout: passo 5, immagine 3 di 3
    • Take your new set screw tub spout and slide it in gently into the wall.
    • Protip: Wiggle the spout side to side to help push it back in.
  6. How to Replace a Leaking Set Screw Tub Spout: passo 6, immagine 1 di 3 How to Replace a Leaking Set Screw Tub Spout: passo 6, immagine 2 di 3 How to Replace a Leaking Set Screw Tub Spout: passo 6, immagine 3 di 3
    • Retighten the set screw using the 5/32" Allen key.
Conclusione
Turn on the bath water to ensure the set screw tub spout has no leaks and is working as intended.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 50
Tutti i Tempi: 4,402
