Introduzione
If your hoodie drawstring is missing, frayed, or stuck inside the hood channel, use this guide to replace it with a new one. The drawstring allows you to adjust the hood's fit for comfort and protection from wind or rain.
Before beginning this guide, check your hoodie's drawstring channel for obstructions or damage. Check for frayed edges, twisted fabric, or any blockages that may prevent the new drawstring from threading smoothly. If the channel is torn, you may need to repair or stitch it before inserting a new drawstring.
Additionally, make sure your replacement drawstring matches the original length and thickness for a proper fit.
This guide uses a safety pin to help thread the new drawstring through the hood channel, but you can also use a bodkin or similar tool.
Cosa ti serve
If the broken or old drawstring is still in the hood, gently pull it through one of the hood holes.
Replacing a hoodie drawstring is a quick, simple repair that saves your favorite hoodie from the donation pile. You can use this same method for sweatpants, jackets, or gym bags.
