Salta al contenuto principale
How to Replace a Broken Window Wand Tilt Mechanism
  1. How to Replace a Broken Window Wand Tilt Mechanism, Wand Tilt Mechanism: passo 1, immagine 1 di 3 How to Replace a Broken Window Wand Tilt Mechanism, Wand Tilt Mechanism: passo 1, immagine 2 di 3 How to Replace a Broken Window Wand Tilt Mechanism, Wand Tilt Mechanism: passo 1, immagine 3 di 3
    • Lift up the wand sleeve with your fingers to clear access for the wand to slide out.
    • Once the sleeve is pushed up, rotate the wand horizontally to unhook it from the tilt mechanism.
  2. How to Replace a Broken Window Wand Tilt Mechanism: passo 2, immagine 1 di 2 How to Replace a Broken Window Wand Tilt Mechanism: passo 2, immagine 2 di 2
    • Lift the header board off the window shade by gently prying up and away from the window blind.
  3. How to Replace a Broken Window Wand Tilt Mechanism: passo 3, immagine 1 di 3 How to Replace a Broken Window Wand Tilt Mechanism: passo 3, immagine 2 di 3 How to Replace a Broken Window Wand Tilt Mechanism: passo 3, immagine 3 di 3
    • Unhook the end clips on the window blind by pulling with your fingers toward yourself in an upward motion.
  4. How to Replace a Broken Window Wand Tilt Mechanism: passo 4, immagine 1 di 2 How to Replace a Broken Window Wand Tilt Mechanism: passo 4, immagine 2 di 2
    • Remove the window blind by pulling it away from the brackets.
  5. How to Replace a Broken Window Wand Tilt Mechanism: passo 5, immagine 1 di 3 How to Replace a Broken Window Wand Tilt Mechanism: passo 5, immagine 2 di 3 How to Replace a Broken Window Wand Tilt Mechanism: passo 5, immagine 3 di 3
    • Slide the end cap off the header to allow for more access.
    • Lift the center rod in an upward motion to unlock it from the header.
  6. How to Replace a Broken Window Wand Tilt Mechanism: passo 6, immagine 1 di 3 How to Replace a Broken Window Wand Tilt Mechanism: passo 6, immagine 2 di 3 How to Replace a Broken Window Wand Tilt Mechanism: passo 6, immagine 3 di 3
    • Remove the tilt wand mechanism by sliding it off the center rod.
  7. How to Replace a Broken Window Wand Tilt Mechanism: passo 7, immagine 1 di 3 How to Replace a Broken Window Wand Tilt Mechanism: passo 7, immagine 2 di 3 How to Replace a Broken Window Wand Tilt Mechanism: passo 7, immagine 3 di 3
    • Install the new tilt wand mechanism by sliding it on the center rod.
    • Once slid into position, reinsert the center rod by pushing down on the assembly.
  8. How to Replace a Broken Window Wand Tilt Mechanism: passo 8, immagine 1 di 1
    • Visually inspect alignment, fitment, and proper function of the newly installed tilt wand mechanism.
    • Insure the clip is securely held in place.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 20
Ultimi 7 Giorni: 147
Ultimi 30 Giorni: 542
Tutti i Tempi: 17,001
