Salta al contenuto principale
How to Replace a Bicycle Bell Disc
Cosa ti serve
  1. How to Replace a Bicycle Bell Disc, Disc Bell: passo 1, immagine 1 di 2 How to Replace a Bicycle Bell Disc, Disc Bell: passo 1, immagine 2 di 2
    • Unscrew the exterior bell housing by rotating clockwise, then remove the housing.
  2. How to Replace a Bicycle Bell Disc: passo 2, immagine 1 di 2 How to Replace a Bicycle Bell Disc: passo 2, immagine 2 di 2
    • Rotate the parallel bars clockwise until they separate from the rod they're mounted on.
  3. How to Replace a Bicycle Bell Disc: passo 3, immagine 1 di 2 How to Replace a Bicycle Bell Disc: passo 3, immagine 2 di 2
    • Remove the rubber discs.
    • Grab your new rubber discs and insert one at each end of the parallel bars.
    • Make sure center of the rubber discs are held in place by the pins.
  4. How to Replace a Bicycle Bell Disc: passo 4, immagine 1 di 1
    • Test and rotate the discs with your finger to see if it is the appropriate size.
    • If the disc does not rotate easily, change the size of your metal disc to a narrower one.
  5. How to Replace a Bicycle Bell Disc: passo 5, immagine 1 di 2 How to Replace a Bicycle Bell Disc: passo 5, immagine 2 di 2
    • Rotate the parallel bars counterclockwise, into their original position.
  6. How to Replace a Bicycle Bell Disc: passo 6, immagine 1 di 2 How to Replace a Bicycle Bell Disc: passo 6, immagine 2 di 2
    • Replace the exterior housing and rotate it counterclockwise until it's fully secure.
Conclusione
Your bell should now be ringing like new!
Susan
Membro da: 01/19/22
133 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 73
Tutti i Tempi: 2,068
