Salta al contenuto principale
How to Replace a 2017 Honda Civic LX Cabin Filter
Cosa ti serve
  1. How to Replace a 2017 Honda Civic LX Cabin Filter, Cabin Filter: passo 1, immagine 1 di 1
    • Direct your attention to the glove compartment directly in front of the front passenger seat.
  2. How to Replace a 2017 Honda Civic LX Cabin Filter: passo 2, immagine 1 di 2 How to Replace a 2017 Honda Civic LX Cabin Filter: passo 2, immagine 2 di 2
    • Open the glove compartment using the handle on the left-hand side.
    • It will open slightly towards you.
    • If you have any items in the glove compartment, remove them and set them aside.
  3. How to Replace a 2017 Honda Civic LX Cabin Filter: passo 3, immagine 1 di 2 How to Replace a 2017 Honda Civic LX Cabin Filter: passo 3, immagine 2 di 2
    • Reach inside the glove compartment and press on the two outer walls on each side of the storage box.
    • Lower the glove compartment down to the ground.
  4. How to Replace a 2017 Honda Civic LX Cabin Filter: passo 4, immagine 1 di 3 How to Replace a 2017 Honda Civic LX Cabin Filter: passo 4, immagine 2 di 3 How to Replace a 2017 Honda Civic LX Cabin Filter: passo 4, immagine 3 di 3
    • Reach into the space behind where the storage box previously rested and pull out the black, plastic panel with raised hexagonal lines.
    • This is the cover for the cabin air filter.
  5. How to Replace a 2017 Honda Civic LX Cabin Filter: passo 5, immagine 1 di 3 How to Replace a 2017 Honda Civic LX Cabin Filter: passo 5, immagine 2 di 3 How to Replace a 2017 Honda Civic LX Cabin Filter: passo 5, immagine 3 di 3
    • Pull out the cloth air filter from the space behind the air filter cover.
    • Dispose of the old air filter.
  6. How to Replace a 2017 Honda Civic LX Cabin Filter: passo 6, immagine 1 di 2 How to Replace a 2017 Honda Civic LX Cabin Filter: passo 6, immagine 2 di 2
    • Unwrap your new air filter and insert it into the empty air filter compartment.
    • On the side of your new air filter you will see air flow markings. Be sure to insert the new air filter so that the air flow markings point down to the ground.
  7. How to Replace a 2017 Honda Civic LX Cabin Filter: passo 7, immagine 1 di 3 How to Replace a 2017 Honda Civic LX Cabin Filter: passo 7, immagine 2 di 3 How to Replace a 2017 Honda Civic LX Cabin Filter: passo 7, immagine 3 di 3
    • Double-check that the air filter is securely all the way into the compartment.
    • Place the black, plastic air filter cover back into place and push it firmly to secure.
  8. How to Replace a 2017 Honda Civic LX Cabin Filter: passo 8, immagine 1 di 1
    • Push on the sides of the storage box and lift the glove compartment back into place.
  9. How to Replace a 2017 Honda Civic LX Cabin Filter: passo 9, immagine 1 di 1
    • Close your glove compartment and you're done!
Conclusione
Enjoy a breath of fresh air as your cabin air filter has now been replaced!
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 76
Ultimi 30 Giorni: 303
Tutti i Tempi: 4,373
