Salta al contenuto principale
How to Replace a 2009-2015 Toyota Venza Brake Light
Cosa ti serve
  1. How to Replace a 2009-2015 Toyota Venza Brake Light, Incandescent Brake Light: passo 1, immagine 1 di 1
    • Turn the car completely off and wait 30 minutes to ensure that the bulb is not hot.
    • If the car has not been on recently, then skip this step.
  2. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 2, immagine 1 di 2 How to Replace a 2009-2015 Toyota Venza Brake Light: passo 2, immagine 2 di 2
    • Open the back trunk.
  3. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 3, immagine 1 di 3 How to Replace a 2009-2015 Toyota Venza Brake Light: passo 3, immagine 2 di 3 How to Replace a 2009-2015 Toyota Venza Brake Light: passo 3, immagine 3 di 3
    • Use a flathead screwdriver to remove the vent located on the inside wall of the trunk.
  4. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 4, immagine 1 di 2 How to Replace a 2009-2015 Toyota Venza Brake Light: passo 4, immagine 2 di 2
    • Carefully reach your arm into the vent and locate the back of the socket.
    • Turn the socket counterclockwise to loosen it.
    • When loose, pull it out into view.
    • The brake bulb socket will be towards the top of the vent.
    • Ensure that bulb has had at least 30 minutes to cool. Touching the bulb while it is hot could result in burns.
  5. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 5, immagine 1 di 2 How to Replace a 2009-2015 Toyota Venza Brake Light: passo 5, immagine 2 di 2
    • Gently pull on the base of the bulb to loosen it from the socket.
    • When loose, remove the bulb from the socket.
  6. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 6, immagine 1 di 1
    • Carefully discard of the old bulb, and acquire the new bulb.
    • Wearing latex gloves when handling the new bulb(s) is highly recommended.
  7. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 7, immagine 1 di 1
    • Add bulb grease to the base of the new bulb.
  8. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 8, immagine 1 di 1
    • Return bulb to the socket by gently pushing the base of bulb into the empty socket until it clicks in.
  9. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 9, immagine 1 di 1
    • Reach your arm into the vent and locate the socket’s hole.
    • Replace the bulb and socket by screwing clockwise to tighten it.
  10. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 10, immagine 1 di 2 How to Replace a 2009-2015 Toyota Venza Brake Light: passo 10, immagine 2 di 2
    • Replace the vent into the wall of the trunk.
    • You will know that the vent is properly closed when it “pops” into place.
  11. How to Replace a 2009-2015 Toyota Venza Brake Light: passo 11, immagine 1 di 1
    • To test your new brake light, have an individual stand behind your car while you press on the brake. The light should come on when the brake is pressed.
    • Enjoy the new lights!
Conclusione
To replace your brake light on the other side, follow these same instructions. Otherwise, safe travels!
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 63
Tutti i Tempi: 1,304
