Salta al contenuto principale
How to Replace T-fal Avante T24-B Toaster Lever
Cosa ti serve
  1. How to Replace T-fal Avante T24-B Toaster Lever, T-fal Avante T24-B Toaster Lever: passo 1, immagine 1 di 1
    • Make sure the toaster is unplugged before beginning.
  2. How to Replace T-fal Avante T24-B Toaster Lever: passo 2, immagine 1 di 3 How to Replace T-fal Avante T24-B Toaster Lever: passo 2, immagine 2 di 3 How to Replace T-fal Avante T24-B Toaster Lever: passo 2, immagine 3 di 3
    • Remove the snap-on buttons from the front of the toaster.
    • They can be removed by pulling with your hands or gently prying with a flat tool.
  3. How to Replace T-fal Avante T24-B Toaster Lever: passo 3, immagine 1 di 3 How to Replace T-fal Avante T24-B Toaster Lever: passo 3, immagine 2 di 3 How to Replace T-fal Avante T24-B Toaster Lever: passo 3, immagine 3 di 3
    • Flip the toaster so that you can see its underside.
    • Remove the seven 20 mm Torx T3 screws from the bottom of the toaster.
  4. How to Replace T-fal Avante T24-B Toaster Lever: passo 4, immagine 1 di 2 How to Replace T-fal Avante T24-B Toaster Lever: passo 4, immagine 2 di 2
    • Turn the toaster so that you can access the back of the toaster
    • Remove the 3 15 mm Torx T3 screws from the back of the toaster.
  5. How to Replace T-fal Avante T24-B Toaster Lever: passo 5, immagine 1 di 2 How to Replace T-fal Avante T24-B Toaster Lever: passo 5, immagine 2 di 2
    • Pull off the toaster casing.
  6. How to Replace T-fal Avante T24-B Toaster Lever: passo 6, immagine 1 di 2 How to Replace T-fal Avante T24-B Toaster Lever: passo 6, immagine 2 di 2
    • Unplug the casing so that it does not get in your way.
    • Unplug both wires connecting the casing to the internals of the toaster.
  7. How to Replace T-fal Avante T24-B Toaster Lever: passo 7, immagine 1 di 3 How to Replace T-fal Avante T24-B Toaster Lever: passo 7, immagine 2 di 3 How to Replace T-fal Avante T24-B Toaster Lever: passo 7, immagine 3 di 3
    • Pry both sides of the broken lever at the front of the toaster away and remove it.
  8. How to Replace T-fal Avante T24-B Toaster Lever: passo 8, immagine 1 di 3 How to Replace T-fal Avante T24-B Toaster Lever: passo 8, immagine 2 di 3 How to Replace T-fal Avante T24-B Toaster Lever: passo 8, immagine 3 di 3
    • Snap the replacement lever into place.
    • Attach one side first, then snap the other side on to fully attach the lever.
Conclusione
Cameron Johnson
Membro da: 01/16/23
157 Reputazione
1 Guida realizzata
2Commenti sulla guida
Thank you so much!
S J - Replica
where do you get the replacement lever ?
Francois Rehel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 37
Tutti i Tempi: 1,213
