Salta al contenuto principale
How to Replace Scott Mountain Bike Handlebars
Cosa ti serve
  1. How to Replace Scott Mountain Bike Handlebars, Scott Mountain Bike Handlebars: passo 1, immagine 1 di 2 How to Replace Scott Mountain Bike Handlebars, Scott Mountain Bike Handlebars: passo 1, immagine 2 di 2
    • Prop bike upright
    • Unscrew the hex bolts holding the front and rear shifter in place.
    • Use the H4 size hex wrench
    • Repeat for other side of handlebars.
  2. How to Replace Scott Mountain Bike Handlebars: passo 2, immagine 1 di 1
    • Slide the shifters toward the center of the handlebars so there is a gap between them and the grips.
  3. How to Replace Scott Mountain Bike Handlebars: passo 3, immagine 1 di 1
    • Use a flathead screwdriver to wedge a gap between the grip and the handlebars.
    • Twist grip around until it comes off of handlebar.
  4. How to Replace Scott Mountain Bike Handlebars: passo 4, immagine 1 di 1
    • Slide the shifters off of the end of the handlebars.
    • Let them hang on the bike.
  5. How to Replace Scott Mountain Bike Handlebars: passo 5, immagine 1 di 1
    • Unscrew the hex bolts holding the center bracket in place.
    • Use H3 hex wrench.
    • Place center bracket and hex screws off to the side. They will be needed in the next step.
  6. How to Replace Scott Mountain Bike Handlebars: passo 6, immagine 1 di 1
    • Attach new handlebars and screw the center bracket back in place.
    • Make sure that handlebars are centered.
  7. How to Replace Scott Mountain Bike Handlebars: passo 7, immagine 1 di 1
    • Slide the shifters back onto the handlebars so that the numbers are upright.
    • Do not screw them back in place yet.
  8. How to Replace Scott Mountain Bike Handlebars: passo 8, immagine 1 di 1
    • Slide the handlebar grips back onto the ends of the handlebars.
    • Slide the shifters back against the grips and screw them into place.
Conclusione
By following these steps, you will have your bike ready in no time.
Sean Slater
Membro da: 02/24/15
139 Reputazione
1 Guida realizzata
Cal Poly, Team 23-3, Green Winter 2015 Membro di Cal Poly, Team 23-3, Green Winter 2015
CPSU-GREEN-W15S23G3
6 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,844
