Introduzione
Gli occhiali da vista sono composti da una montatura e due lenti. La montatura è la parte esterna in metallo o in plastica degli occhiali. I lati che poggiano sulle orecchie sono chiamati "aste".
Le lenti sono quel pezzo di vetro che si trova davanti agli occhi. A volte la montatura degli occhiali può allentarsi e la lente potrebbe fuoriuscire. Con questa guida, sarai in grado di riposizionare facilmente una lente nella montatura.
Cosa ti serve
Individua la vite sulla cerniera angolare degli occhiali, tra le lenti e le aste, e svitalo utilizzando il cacciavite da 1.5mm, ruotandolo in senso antiorario.
Altre 9 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
3Commenti sulla guida
I just remember my glasses was broken like this, I just return my glasses to finestglasses.com and they fix it up for me. Thanks them to make exception for not charge me any money.
I have older lens I had placed in new frames. The lens kept falling out even with the screws being tight. I brought in the glasses back to the Walmart Eye glasses shop, cleaned the lens edges and tightened them back in. This did not help. I remember as a kid that the optometrist had a not sticky tape that they placed around the lens which helped hold it in. I asked about this but the shop did not know what I was referring to. I had just been fixing a loose nut and bolt with some plummer’s tape on it to hold. So after my lens fell out of my frame again while clearing snow I tried using the tape. I wrapped the stretchy plastic tape around the lens and popped it in. Then with a new razor I cut the tape around the rim and it held- Yeah.
There is also a product called Sugru that is moldable glue that is great for this problem that Andrew Sparber had with this glasses. We use it to repair frame breaks in sunglasses for our customers, it’s super tough and really holds broken glasses frames together. You can buy it at www.sugru.com.
