Salta al contenuto principale
How to Replace Keys on a Keyboard
Cosa ti serve
  1. How to Replace Keys on a Keyboard, Individual Keys: passo 1, immagine 1 di 2 How to Replace Keys on a Keyboard, Individual Keys: passo 1, immagine 2 di 2
    • Loosen the key by prying all four corners gently with your spudger.
    • Make sure your keyboard is unplugged before performing any of these steps.
  2. How to Replace Keys on a Keyboard: passo 2, immagine 1 di 2 How to Replace Keys on a Keyboard: passo 2, immagine 2 di 2
    • Wedge the tip of the spudger under the bottom of the key and carefully lift up until the key pops loose.
    • If the key will not come out, or seems like too much force is needed, try step one again.
  3. How to Replace Keys on a Keyboard: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to remove any contaminants that were preventing the key from being pressed down from the now open hole on your keyboard.
    • Do not to grab the actual button, as breaking that could damage your keyboard permanently.
  4. How to Replace Keys on a Keyboard: passo 4, immagine 1 di 1
    • Clean your keys with compressed air by blowing around the removed key.
  5. How to Replace Keys on a Keyboard: passo 5, immagine 1 di 2 How to Replace Keys on a Keyboard: passo 5, immagine 2 di 2
    • Push in the clean keys until you hear a popping sound.
    • The keys should click in easily, so if you are having trouble try realigning the key with its hole.
    • If you removed multiple keys, make sure they are in their proper spot and orientation.
Conclusione
Congratulations! You now have a keyboard with fully functional keys!
Altre 7 persone hanno completato questa guida.
Cooper
Membro da: 02/24/15
493 Reputazione
2 Guide realizzate
Cal Poly, Team 24-6, Green Winter 2015 Membro di Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
4 Membri
16 Guide realizzate
2Commenti sulla guida
This is How to CLEAN keys, not replace them. Duh.
Mike Miller - Replica
I came looking for how to replace the problematic ones like + on numpad :<
Eskalina Cvrnkalikova - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 180
Tutti i Tempi: 19,973
