Salta al contenuto principale
How to Replace HID Headlight Bulbs
  1. How to Replace HID Headlight Bulbs, HID Headlight Bulb: passo 1, immagine 1 di 2 How to Replace HID Headlight Bulbs, HID Headlight Bulb: passo 1, immagine 2 di 2
    • Open the hood and then locate the back of the headlights.
    Chiedi a FixBot
    Aggiungi Commento
  2. How to Replace HID Headlight Bulbs: passo 2, immagine 1 di 1
    • Remove the cap covers behind the headlights.
    Chiedi a FixBot
    Aggiungi Commento
  3. How to Replace HID Headlight Bulbs: passo 3, immagine 1 di 2 How to Replace HID Headlight Bulbs: passo 3, immagine 2 di 2
    • Once you can see the OEM headlight bulb, twist and unlock to take it out.
    Chiedi a FixBot
    Aggiungi Commento
  4. How to Replace HID Headlight Bulbs: passo 4, immagine 1 di 2 How to Replace HID Headlight Bulbs: passo 4, immagine 2 di 2
    • For a lot of D1S and D3S, there's a bulb retainer, which you will need to remove.
    Chiedi a FixBot
    Aggiungi Commento
  5. How to Replace HID Headlight Bulbs: passo 5, immagine 1 di 1
    • Examine your stock bulb. Make sure that the labeling on the OEM bulb is the same as the new HID bulb.
    • For example, this particular vehicle uses D1S stock bulb. You'll need to make sure that the HID replacement bulb is also labeled as D1S.
    • D1S and D3S are not interchangeable, so if you find that the labeling does not match, you will need to exchange for the correct size.
    Chiedi a FixBot
    Aggiungi Commento
  6. How to Replace HID Headlight Bulbs: passo 6, immagine 1 di 3 How to Replace HID Headlight Bulbs: passo 6, immagine 2 di 3 How to Replace HID Headlight Bulbs: passo 6, immagine 3 di 3
    • Take a look at the pins inside of the bulb. You can see that there is 1 pin by itself, a gap, and then 2 pins together. When you connect the new HID headlight bulb to the adapter, the pin direction needs to match! Look closely at the adapter and you will see numbers denoting slots 1,2, and 4.
    • Make sure that the pins on the HID headlight bulb and the pin slots on the adapter directly match prior to connection. If you connect the HID headlight bulb and the adapter the wrong way, the connection will still go in, but the incorrect insert WILL cause the bulb to have issues such as not lighting up, flickering, or damage to your vehicle.
    • So before connecting the HID headlight bulb to the adapter, make sure that the pins from the HID headlight bulb match the corresponding open slots on the adapter.
    Chiedi a FixBot
    Aggiungi Commento
  7. How to Replace HID Headlight Bulbs: passo 7, immagine 1 di 2 How to Replace HID Headlight Bulbs: passo 7, immagine 2 di 2
    • Now you can install the HID headlight bulb back with the original retainer and then insert it back the same way you removed the OEM bulb.
    Chiedi a FixBot
    Aggiungi Commento
  8. How to Replace HID Headlight Bulbs: passo 8, immagine 1 di 2 How to Replace HID Headlight Bulbs: passo 8, immagine 2 di 2
    • Put all the components back in place and enjoy your new HID headlights.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
As you can see, it's very straight forward to install. Installing this HID Replacement Bulb will give you light when yours burnt out.
Altre 7 persone hanno completato questa guida.
Eric Wu
Membro da: 01/21/15
3.600 Reputazione
23 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 9
Ultimi 7 giorni: 78
Ultimi 30 giorni: 369
Tutti i Tempi: 10,111
