Salta al contenuto principale
How to Replace Big Berkey Water Filters
Cosa ti serve
  1. How to Replace Big Berkey Water Filters, Filters: passo 1, immagine 1 di 2 How to Replace Big Berkey Water Filters, Filters: passo 1, immagine 2 di 2
    • Take the top half of your Berkey off, and place it to the side of your work station.
  2. How to Replace Big Berkey Water Filters: passo 2, immagine 1 di 2 How to Replace Big Berkey Water Filters: passo 2, immagine 2 di 2
    • Unscrew the White Elements by twisting counterclockwise.
  3. How to Replace Big Berkey Water Filters: passo 3, immagine 1 di 3 How to Replace Big Berkey Water Filters: passo 3, immagine 2 di 3 How to Replace Big Berkey Water Filters: passo 3, immagine 3 di 3
    • Unscrew the Black Element filters by twisting the black washers counterclockwise.
    • Remove the filters from the top compartment.
  4. How to Replace Big Berkey Water Filters: passo 4, immagine 1 di 2 How to Replace Big Berkey Water Filters: passo 4, immagine 2 di 2
    • Clean both the top and bottom tank compartments with a sponge.
    • Make sure to scrub both compartments clean of any mineral build-up that may have accumulated.
  5. How to Replace Big Berkey Water Filters: passo 5, immagine 1 di 3 How to Replace Big Berkey Water Filters: passo 5, immagine 2 di 3 How to Replace Big Berkey Water Filters: passo 5, immagine 3 di 3
    • Securely attach the priming tool to the Black Elements nozzle.
    • Push the filter nozzle against the tap for 10 seconds per filter to remove any impurities.
    • Run your sink water at a medium to slow flow-rate, to avoid water spraying everywhere.
  6. How to Replace Big Berkey Water Filters: passo 6, immagine 1 di 2 How to Replace Big Berkey Water Filters: passo 6, immagine 2 di 2
    • Leave equipment to air dry.
  7. How to Replace Big Berkey Water Filters: passo 7, immagine 1 di 3 How to Replace Big Berkey Water Filters: passo 7, immagine 2 di 3 How to Replace Big Berkey Water Filters: passo 7, immagine 3 di 3
    • Place your new Black Element filters through the holes in the top compartment.
    • Continue to screw the washer around the nozzle to secure the Black Element in place.
  8. How to Replace Big Berkey Water Filters: passo 8, immagine 1 di 3 How to Replace Big Berkey Water Filters: passo 8, immagine 2 di 3 How to Replace Big Berkey Water Filters: passo 8, immagine 3 di 3
    • Screw our new White Element filters over the nozzle of the Black Element filters, and repeat to attach all pieces securely.
  9. How to Replace Big Berkey Water Filters: passo 9, immagine 1 di 1
    • Enjoy your clean and purified drinking water from your Big Berkey for years to come.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 68
Tutti i Tempi: 603
