Introduzione
This guide will help you increase your reels performance and maintain your reels' durability. I recommend taping your line to the spool before beginning this process if your reel has line on it. This will keep your spool nice and tidy. Remember to be careful when disassembling and reassembling the fishing reel. Happy Fixing!
Cosa ti serve
Use a pair of pliers to remove the pin. There should be a big and small side of the pin. Remove the pin pushing from the smaller side in order to not strip the casing it sits in. It may take a little force, but try to be as gentle as possible.
After removing the pin pull out the bearing and replace it with a new one.
To reassemble your device, follow these instructions in reverse order. Remember to take your time, be very delicate, and be sure to assemble the device with all of the required pieces in order.
