Salta al contenuto principale
How to Repair the Tip of a Fishing Rod
Cosa ti serve
  1. How to Repair the Tip of a Fishing Rod, Tip of a Fishing Rod: passo 1, immagine 1 di 3 How to Repair the Tip of a Fishing Rod, Tip of a Fishing Rod: passo 1, immagine 2 di 3 How to Repair the Tip of a Fishing Rod, Tip of a Fishing Rod: passo 1, immagine 3 di 3
    • Determine what tip fits the fishing rod the best.
    • A tight fit is preferable and will have the best outcome for the repair.
  2. How to Repair the Tip of a Fishing Rod: passo 2, immagine 1 di 3 How to Repair the Tip of a Fishing Rod: passo 2, immagine 2 di 3 How to Repair the Tip of a Fishing Rod: passo 2, immagine 3 di 3
    • Melt the tip of the glue stick with a lighter.
    • Use a paper towel underneath the area you melt the glue because it can melt very quickly and drip on the surface where you are working.
    • Take the necessary precautions when applying heat to the glue stick because an open flame and hot glue are involved and can burn skin and other things.
  3. How to Repair the Tip of a Fishing Rod: passo 3, immagine 1 di 3 How to Repair the Tip of a Fishing Rod: passo 3, immagine 2 di 3 How to Repair the Tip of a Fishing Rod: passo 3, immagine 3 di 3
    • Apply the melted glue immediately around the top of the rod.
  4. How to Repair the Tip of a Fishing Rod: passo 4, immagine 1 di 3 How to Repair the Tip of a Fishing Rod: passo 4, immagine 2 di 3 How to Repair the Tip of a Fishing Rod: passo 4, immagine 3 di 3
    • Immediately apply the melted glue around the tip you are going to use.
    • If the glue stick cooled, apply heat again to make it useful.
  5. How to Repair the Tip of a Fishing Rod: passo 5, immagine 1 di 3 How to Repair the Tip of a Fishing Rod: passo 5, immagine 2 di 3 How to Repair the Tip of a Fishing Rod: passo 5, immagine 3 di 3
    • Put the tip on top on the rod immediately after doing steps 3 and 4.
    • Be sure to align the tip with the other guides on the rod.
    • If between steps the glue dried on either part, reapply heat to soften the glue so the parts fit together.
  6. How to Repair the Tip of a Fishing Rod: passo 6, immagine 1 di 1
    • Allow the glue to cool.
  7. How to Repair the Tip of a Fishing Rod: passo 7, immagine 1 di 3 How to Repair the Tip of a Fishing Rod: passo 7, immagine 2 di 3 How to Repair the Tip of a Fishing Rod: passo 7, immagine 3 di 3
    • Apply some heat to the fishing rod and remove the excess glue with a paper towel.
    • Let it cool down again.
Conclusione
When you put the tip on the rod with the glue, verify that it is align with the other guides and let it cooled down. If you have excess of glue, apply some heat with the lighter and let it cooled down again. After that, your are ready to go fishing!
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,835
