Salta al contenuto principale
How to Repair the Sparker on a Merlion Mini Torch
Cosa ti serve
  1. How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: passo 1, immagine 1 di 3 How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: passo 1, immagine 2 di 3 How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: passo 1, immagine 3 di 3
    • Use the screwdriver to remove all the 1.2 mm Phillips #1 countersunk screws from the torch.
  2. How to Repair the Sparker on a Merlion Mini Torch: passo 2, immagine 1 di 2 How to Repair the Sparker on a Merlion Mini Torch: passo 2, immagine 2 di 2
    • Open up the torch.
    • Set aside the empty side of the torch.
  3. How to Repair the Sparker on a Merlion Mini Torch: passo 3, immagine 1 di 3 How to Repair the Sparker on a Merlion Mini Torch: passo 3, immagine 2 di 3 How to Repair the Sparker on a Merlion Mini Torch: passo 3, immagine 3 di 3
    • Pull the handle down as if you were to use the torch.
    • You will see one of the parts inside spark. This is the sparker.
    • Now gently remove the handle and set it aside.
  4. How to Repair the Sparker on a Merlion Mini Torch: passo 4, immagine 1 di 2 How to Repair the Sparker on a Merlion Mini Torch: passo 4, immagine 2 di 2
    • Grab your pliers and GENTLY tug the sparker towards the Merlion head until it is extended about a centimeter.
  5. How to Repair the Sparker on a Merlion Mini Torch: passo 5, immagine 1 di 2 How to Repair the Sparker on a Merlion Mini Torch: passo 5, immagine 2 di 2
    • Gently bend the sparker until it is positioned near the opening of the Merlion's mouth.
  6. How to Repair the Sparker on a Merlion Mini Torch: passo 6, immagine 1 di 3 How to Repair the Sparker on a Merlion Mini Torch: passo 6, immagine 2 di 3 How to Repair the Sparker on a Merlion Mini Torch: passo 6, immagine 3 di 3
    • Grab the tube and gently bend it so it faces the opening of the Merlion's mouth.
    • Put the handle back on the torch.
  7. How to Repair the Sparker on a Merlion Mini Torch: passo 7, immagine 1 di 3 How to Repair the Sparker on a Merlion Mini Torch: passo 7, immagine 2 di 3 How to Repair the Sparker on a Merlion Mini Torch: passo 7, immagine 3 di 3
    • Take the empty half of the torch and place it over the other half.
  8. How to Repair the Sparker on a Merlion Mini Torch: passo 8, immagine 1 di 3 How to Repair the Sparker on a Merlion Mini Torch: passo 8, immagine 2 di 3 How to Repair the Sparker on a Merlion Mini Torch: passo 8, immagine 3 di 3
    • Use the screwdriver to put the screws back in the torch.
  9. How to Repair the Sparker on a Merlion Mini Torch: passo 9, immagine 1 di 2 How to Repair the Sparker on a Merlion Mini Torch: passo 9, immagine 2 di 2
    • Hold the torch upside down and position the butane above the torch's hole.
    • Gently press down for five seconds.
Conclusione
Congrats! Now you can use your Merlion torch again.
Altre 3 persone hanno completato questa guida.
Neel Kogali
Membro da: 09/29/15
200 Reputazione
1 Guida realizzata
Cal Poly, Team 14-3, Green Fall 2015 Membro di Cal Poly, Team 14-3, Green Fall 2015
CPSU-GREEN-F15S14G3
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 7,623
