Is there a broken rear cup holder in your 2005-2013 Nissan Frontier? Use this guide to learn about the steps involved with repairing this broken rear cup holder.
Slide the front seat forward by raising the lever located on the front of the seat, near the console, and sliding the seat forward.
Do this for both front seats.
After sliding the front seats forward, you need to fold them forward as well.
Push up on the lever located on the side of the front seat. Hold the lever up until the seat folds forward.
Make sure the broken rear cup holder is open enough to fit your hand inside.
Remove the rear cup holder by using both hands to press in and up on the cup holder itself.
The cup holder should "pop" out of the console.
Separate the front and back parts of the cup holder by opening one of the two cup holder arms.
Slowly remove the front part of the cup holder by adjusting one side of the cup holder until it is able to break free.
Take the entire front part of the cup holder out from the back part of the cup holder.
Check all sides of the cup holder to see what parts are broken. Front, Back, side to side.
This is an extremely important step which will help you understand where you will need to put the super glue later in this repair process.
Re-insert the shorter end of the spring into the back part of the cup holder.
Re-insert the longer end of the spring into the front part of the cup holder.
It is crucial to make sure the spring is properly inserted between both the front and back parts of the cup holder.
Check to see if the broken parts of the cup holder have stayed connected by the glue, by pressing them together for about 2 minutes
Make sure the broken parts of the cup holder are glued together correctly.
Ensure that before the glue dries that the cup holder can be easily opened and closed with no resistance.
You may have to reapply the super glue if the cup holder is unable to open and close with no resistance.
Incorpora questa guida
Scegli una dimensione e copia il codice qui sotto per incorporare questa guida come un piccolo widget sul tuo sito/forum.
Passo Singolo
Guida Completa
Piccolo - 600px
Medio - 800 px
Grande - 1200 px
Anteprima
