Salta al contenuto principale
How to Repair the Buttons on a Logitech Pebble Mouse
Cosa ti serve
  1. How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: passo 1, immagine 1 di 3 How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: passo 1, immagine 2 di 3 How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: passo 1, immagine 3 di 3
    • Use your hands to remove the magnetic top panel of the mouse.
  2. How to Repair the Buttons on a Logitech Pebble Mouse: passo 2, immagine 1 di 3 How to Repair the Buttons on a Logitech Pebble Mouse: passo 2, immagine 2 di 3 How to Repair the Buttons on a Logitech Pebble Mouse: passo 2, immagine 3 di 3
    • Remove the USB adaptor in the small rectangular hole on the lower right corner.
    • Remove the battery.
  3. How to Repair the Buttons on a Logitech Pebble Mouse: passo 3, immagine 1 di 2 How to Repair the Buttons on a Logitech Pebble Mouse: passo 3, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove one screw holding the inner panel in place.
  4. How to Repair the Buttons on a Logitech Pebble Mouse: passo 4, immagine 1 di 3 How to Repair the Buttons on a Logitech Pebble Mouse: passo 4, immagine 2 di 3 How to Repair the Buttons on a Logitech Pebble Mouse: passo 4, immagine 3 di 3
    • Remove the the inner panel.
    • This may take a little bit of effort but it should come off fairly easily.
    • You can use the battery socket as leverage to remove the panel. To avoid breaking the panel, be gentle but firm.
  5. How to Repair the Buttons on a Logitech Pebble Mouse: passo 5, immagine 1 di 1
    • Use a fine-tipped object or a Q-tip and dip it in a small amount of oil.
  6. How to Repair the Buttons on a Logitech Pebble Mouse: passo 6, immagine 1 di 3 How to Repair the Buttons on a Logitech Pebble Mouse: passo 6, immagine 2 di 3 How to Repair the Buttons on a Logitech Pebble Mouse: passo 6, immagine 3 di 3
    • Gently wipe the metal axle where the scroll wheel is mounted with a small amount of 3-in-1 oil.
    • Repeat for the left and right click buttons.
Conclusione
Emma Whitmer
Membro da: 04/19/23
151 Reputazione
1 Guida realizzata
UC Davis, Team 2-6, Morris Spring 2023 Membro di UC Davis, Team 2-6, Morris Spring 2023
UCD-MORRIS-S23S2G6
3 Membri
1 Guida realizzata
2 Commenti
At first i'm laugh about fixing button with oil, but then i tried it... and it worked like a charm!
Marat - Replica
I didn't even disassemble (unscrew) my pebble. Just applied a drop of mineral oil to the button and it did help a lot! Thanks!
Tomek Luzak - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 41
Ultimi 30 Giorni: 147
Tutti i Tempi: 1,900
